battery died
battery died
well, i just checked on my car today and it looks like my battery is completely drained or near drained. i tried to used a jumper box but that didn't seem to do the trick.
so do i need to buy a new battery or can the one drained battery be re-charged. the battery is about 3yrs old now.
tia
gary
tia
gary
Try taking it out and charging it at a local shop over night (good 8 hours). Also have them do a test on it to see if it's still good. I recently thought mine was dead when it just needed a long charge. 997s draw more milli amps then most cars while sitting in storage so it's common for it to die after a month or so of hibernating.
thread on this right next to yours- I just had this happen as well, click here: https://www.6speedonline.com/forums/...requested.html
tia
gary
tia
gary
Changing my battery-any issues?
I'm about to replace the battery on my 997S (2005). Is there any issues/risks that I should be aware of? e.g. memory settings, engine settings, whatever?
Normally, I would never even bother to ask but the P-car seems to be electronically unusual.
So, can I just pull the old one out, fumble around for a while as I am wont to do, and then attach the new one?
My battery died right before I started storing it for the winter. The battery was fine after a recharge (and now on a trickle charge) but I was getting the PASM light so I thought I was going to have to take it to the dealer once spring arrived but I see it should go off by itself.
You may have to go to the dealer for a handover procedure to reactivate functions that revert with loss of power, eg, seat heaters & sport chrono light always on.
Get a better 3rd party battery with higher crank amps, such as a DuraLast from AutoZone. See this BATTERY THREAD.
More specific question
Perhaps I should re-phrase the question...
I'd like to know what happens if I disconnect the battery for an hour or two - prior to replacing it with a new battery. I have the battery, so any tip re the battery type, though appreciated, is not needed. The new one (Braille CF) is a different size, and has a small bracket that I need to adapt to the tray. No big deal, but the car will be without a battery for somewhere from 1/2 hour to 2 or so.
Will there be any need to head down to the dealer for reprogramming, resetting, bill paying .
And (and I presume this is a no-no but one of the responses may be implying this) can I leave the car on a plug-in charger while the battery is out - to prevent any of the issues that may result from a missing battery. I have a Battery Tender that can plug in to the lighter. This is a bit of a heart-lung machine kind of approach but my experience is that you don't want to put a charger on a car without a 'buffer'.
Thanks,
Verde
Thanks,
Verde
Thanks,
Verde
Thanks,
Verde
Connect the battery maintainer and disconnect the battery afterwards. The maintainer will keep things running and no settings will be lost, unless you have some high debit after market doodad which could overload the maintainer.
WheelsupZR1
10-20-2015 08:36 PM
