Proper Oil Choice
As for the Variocam not working with 15W50, that false report was due to some "Porsche expert " yahoo that wrote an article about it and said you had to use 0W40 in order for the system to work.
Since 99% of people believe what they read regardless of whether it makes sense or not, it kinda became accepted as fact.
Mobil 0W40 is as big a con job as is Global Warming being caused by humans. People just suck it up as fact because it's the popular thing to do.
Hey, how's the temperature in New York right now? I guess it's true. There is a sucker born everyday.
Oh yeah, now I remember you. You're the one who believes that burning as much as 9 gallons of oil in your Porsche between changes is perfectly fine because it says so in the manual. I guess that's good for the environment too. You aren't trying to warm things up around your area, are you?
I was waiting for you to show up in an oil thread...you sniff these out in amazing time normally. I was not saying one was better than the other but waqs just sayin gwhat Porsche has said about the proper oil for the car. My shop however says here in Florida and for DE's they recomend 15w-50 and have not had any vario-cam issues. Which on eis correct...Porsche or the independant shop?
Independent shop. They can do what is right, Porsche has to say and do what is necessary for their cars to meet government mandates. As well as to reap the benefits of the substantial contributions Exxon makes to their balance sheet.
Both the indy shop and my dealer both use Mobil 1 so I do not see how the dealer is help Exxon/Mobil over the indy shop. The indy shop will use 0-40 but recomends 15w-50 as long as you are not taking a trip to the north in the winter. Other Porsche dealer acorss town I believe uses Castrol Syntec 5w-50 on their BMW's and Porsche cars.
I've been useing Mobil 1 Synth for a long long time. Used it in my race boat, pleasure boat and cars for well over 20 years.
I have used 0w-40 since 2006 in my 997S cars with out any issues on the track and street.
I live in Florida and I found this odd but my local Porsche shop recomends 15W-50 for 997S cars! I was under the impression that this weight of oil would not allow the Vario-Cam system to operate properly. They said that is not true and they have been oing this with all 2005+ 997 cars with out any issues.
thoughts and opinions?
Just had the same experience at Tech. Dimensions in Jacksonville; they put in Mobil 1 15-50, said it's much better for warm climates, and they have a great reputation. Don't know if it has anything to do with the viscosity but the idiot oil pressure guage seems to have a lot more (and I hope better) variabilty now - before it was always either 4 or 5.
Hey, I respect and thank you for your answer. My 'problem' with the guage is that for the better part of 3 years the guage was always at 5 and would fall back to about 4 when the engine was warm and I was decelerating. I asked several times at a couple of dealerships if this was normal and the answer was always "don't worry about it; if there's a problem the warning light will come on." In the old days with a real guage you knew what range you should be experiencing.
My 997.2 came with a quart of Mobil 0w40 and a cotton towel in a ziploc bag in the front trunk. I'd intended to use that anyway.. got a 6 pack sitting on my garage shelf from my other car (a VW New Beetle). I can only recommend you just stick with whats on the list in the manual and what came with the car. If you want to dig down the rabbit hole and hot discussions about specialty oils and engine additives, be my guest. You won't really come to any clearer answer.. even if you think you did. ;-)
Boy, I cringed when I read this original post... knowing what would happen. The forum did not dissapoint.
Your stock oil gauge should be 4+ bar whenever your engine speed is above 3000 rpm. It should be pegged at cold startup at all engine speeds. It should never fall below 1.5 bar regardless of how hot the engine is.
As far as using the oil brand and weight that came with the car? Does that apply with tires too or have most people moved to a better tirel? It always amazes me how some are smart enough to realize that Porsche might not have put the very best tires on their cars but were right on when it came to the oil.
Thank God it is not publicly known what brand of gasoline came in the car or people would insist in only using that only brand.
Are you inviting me to correct you again? Ok.
The dealer was not referencing the oil level gauge but, in fact, the low oil pressure warning light. Maybe you were not aware of this low oil pressure warning?
Feel better?
The low oil pressure light is a function of low oil level as I understand it. The system will maintain proper pressure until the level drops too low. By the time the light goes on you may have waited too long and are risking engine damage. This is the idiot light being discussed.
