X51 intake AKA engine art
I agree - I would like to do that and the X-51 headers. Probably difficult to answer, but about how much could I expect labor to be to install? I have a feeling my dealer might be reluctant to do it. I'm not much of a DIY'er, but I would be willing to help (hinder) a friend who can do this sort of thing. Depending on how much trouble I am, I would know how much hazardous duty pay to offer him.
Nice. Did you install the aerokit also or was it OEM? Are you going to buy/get the black piece for the left side of aero lid?
My car is a factory X51 car and I wondered about how the aero lid works with the dual snorkels.
It's came from the factory with the aerokit. The left side of the decklid is actually already pre-molded to fit the the intake tube / snorkel. It has the same opening and tilt as the sealing plate on the right side. Therefore the sealing plate won't fit and is not needed. The aerokit decklid needs to be cut on the right side to adapt the sealing plate. It is pretty simple to do since the aerokit decklid is fiberglass.
To install the X51 airbox itself is done in 30 minutes at most. The job is to install the oil extension hose and to cut the decklid nice. Don't forget the extension cable to the MAF, if not the wiring will be very thight.
Suncoast sells a complet package for a good price.
Will check if I find a template for cutting.
Edit. I found it. Send me a PM with email and I send you complete workshop manual for X51 powerkit.
I started with a hole saw then followed the outline of the template with a carborundum disk attached to my air driven grinder. But you could us a Dremel.
Nice!
SuncoastParts.com
Your #1 Source for Genuine Porsche Parts and Accessories on the Web!
Visit us at http://www.SuncoastParts.com
Call us at: 877-923-1700
Email us at: Parts@SuncoastParts.com
Follow us to stay connected:
Join Our Newsletter | Facebook
SuncoastParts.com
My car had a slight rough idle to begin with (I think most do) and with the airbox it might be a tad more pronounced, but I don't really notice it.
Just curious, how much are those other parts aside from the X51 airbox and is that all that needs to be changed for the intake to be totally the same as an OEM X51?
The full X51 kit has different airbox, throttle body, aluminum intake manifold, cylinder heads, exhaust manifolds, PSE unless you have it already, center radiator kit, new rear underbody panel and ECU reprogramming.
04-28-2022 12:38 AM
stevenrmusic
Bentley
17
11-12-2015 05:53 PM
PelicanParts.com
BMW Vendor Classifieds
08-25-2015 03:55 PM
PelicanParts.com
08-25-2015 03:43 PM
Nissan GTR
08-19-2015 02:11 PM
