384 miles and the "Check Engine" light
Today I started the car and drove off and within 5 minutes the "check engine" warning pop up. Sudden the car felt sluggish and jerky, and if the speed goes pass 40 MPH the "check engine" light start flashing. I pumped gas few days ago and the gas cap is close. Can anyone shed some light about this. It feels like the car can't shift properly and not getting enough fuel.
John
John
this is right from the owners manual..."if the check engine light in the instrument panel is flashing, severe catalytic converter damage and power loss will soon occur. Prolonged driving with the check engine light on could cause damage to the emission control system. Have the fault remedied at the nearest authorized Porsche dealer immediately...
sounds like your car is going into "limp" mode and needs attention now
Check Engine Light
As mentioned in one of the post, Check Engine light relates to the emission system. So, your engine / drivetrain should be ok.
Update. Autozone just did a readout and it said "Miss firing in cylinder 3" code#P0303 Now my car is not going to blowup is it? For you knowledgeable guys, what does this mean and solution? And can I still drive short distance? Thanks
John
John
