Best way to launch '07 C2S
Old 06-12-2009, 10:04 AM
mnmatt's Avatar
mnmatt has a brilliant futuremnmatt has a brilliant futuremnmatt has a brilliant futuremnmatt has a brilliant futuremnmatt has a brilliant futuremnmatt has a brilliant futuremnmatt has a brilliant futuremnmatt has a brilliant futuremnmatt has a brilliant futuremnmatt has a brilliant futuremnmatt has a brilliant future
I should correct a couple of things - you will see me at the drag strip Larry, just watching instead of driving.
Second - I feather into first gear targeting 1,100 rpms and then go full throttle once the clutch is fully engaged - which you can feel happen.
Old 06-12-2009, 10:11 AM
NorthVan's Avatar
If you want do burnouts of high rev clutch drops, then you have the wrong car. These cars are not set up for launching, do it too often and you will wear out your clutch and possible break other things.
If you want to do burnouts go buy a new Mustang, the whole car costs about the same as the engine and transmission on a 997.
Old 06-12-2009, 11:00 AM
surfingbuddhist's Avatar
surfingbuddhist has a spectacular aura aboutsurfingbuddhist has a spectacular aura about
Wide rear tires + relatively low torque = no burnouts (except in the wet!)
Old 06-13-2009, 11:49 AM
EJ-997's Avatar
EJ-997 is infamous around these parts
In drag racing (or autocross) a burnout is done to warm up the tires before the start. Warm tires have more traction. During the actual start the tires should not spin.
I would like to know how Porsche gets the 4.7 sec 0-60 mph that is in their specifications.
Old 06-13-2009, 01:28 PM
NorthVan's Avatar
+ traction control.
Mathme
Cayenne 958
03-23-2016 11:47 AM
7thsign
12-12-2015 07:43 PM
calexand
11-05-2015 01:05 PM
Street Fighter
09-28-2015 05:31 PM
panas001
09-27-2015 02:51 PM
Quick Reply: Best way to launch '07 C2S
