Water Spot Removal
Old 07-14-2009, 08:41 PM
gjnockie's Avatar
gjnockie is infamous around these parts
Water Spot Removal
Need some advice on how to safely remove water spots on the roof of my Basalt Black C2S.
Tried to use blue Zymol liquid wax which removed most of them but not all.
Any suggestions?
Old 07-14-2009, 10:08 PM
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
I think you'll need to do a light polish to remove the stains completely. Keep in mind, wax is just a sealant/protectant. It may not be best suited for removing water spots. I'd shoot Phil from Detailers Domain a PM or phone call. He should definitely be able to set you up with some good product to get rid of the spots, or give you some better guidance.
Ironically, I just realized the amount of water spots I have in my paint since moving to South Florida. I have a good wash/clay/polish/wax planned for the near future. Where in Florida are you located? If you're nearby, I'd be happy to give you a hand.
Old 07-14-2009, 11:07 PM
Dave07997S's Avatar
Dave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant future
You can try lemon juice diluted with water...it's acidic enough to remove water stains but won't harm the finish. It may remove wax as well so you may want to rewax the area you used the lemon juice.
Dave
Old 07-15-2009, 10:41 AM
surfingbuddhist's Avatar
surfingbuddhist has a spectacular aura aboutsurfingbuddhist has a spectacular aura about
Try a very fine polishing compound inbetween cleaning the surface and rewaxing. The reason wax doesn't completely remove hard (as opposed to soft) water stains is because it etches the clear coat ever so slightly.
Old 07-15-2009, 02:19 PM
Ced's Avatar
Ced
Ced is offline
Ced is infamous around these parts
Vinegar works too... if the water spots are too bad.
Old 07-15-2009, 05:05 PM
detailersdomain's Avatar
detailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond repute
distilled vinegar will work if it isn't etched. if it is polishing or compound maybe required.
hey tom are you going to waterfest?
Old 07-15-2009, 07:56 PM
ato911's Avatar
ato911 is infamous around these parts
I have used Swissvax Cleaner Fluid followed by an application of Swissvax Zuffenhausen and that has removed the water spots.
Old 07-15-2009, 09:36 PM
yup I'll be there. Flying in tomorrow night.
Old 07-15-2009, 09:58 PM
cool see you there ....have a safe flight..
sat and sun?
I will be in the sander booth got a new toy
Old 07-15-2009, 10:38 PM
gomez's Avatar
gomez has a brilliant futuregomez has a brilliant futuregomez has a brilliant futuregomez has a brilliant futuregomez has a brilliant futuregomez has a brilliant futuregomez has a brilliant futuregomez has a brilliant futuregomez has a brilliant futuregomez has a brilliant futuregomez has a brilliant future
Polish, polish... polish and only then can you hope for results
Old 07-16-2009, 09:43 AM
jlingk's Avatar
jlingk is infamous around these parts
Zaino
Z-PC Fusion Dual Action Paint Cleaner Swirl Remover
DLF
Cayenne 955/957
10
02-28-2022 11:49 PM
NIKAS
08-20-2019 07:53 PM
markj
911
04-07-2016 05:44 PM
Quick Reply: Water Spot Removal
