Fresh Meat For C4S: Bridgestone RE-11 First Impressions
Here are a few first Bridgestone RE-11 First Impressions.
My 07 C4S is a daily driver. I do AX whenever I can and 2 track days a year.
The car has Bilsteins, has been slightly lowered and corner balanced and has an alignment by TC Design Fab. It handles well with a min. of understeer - the handling is quite improved from stock........................
I have previously run PS2s (very good) and Bridgestone RE05As (very good as well). I run 39 psi R and 33psi F, typically.
The first thing I noticed was that the RE-11s had a significantly quieter and plusher ride than RE-05As. This was very noticeable, and was a pleasant surprise. The RE-11s have more of a "gumball feel" as well, the 05As seem to have more road feel in that every nuance is transmitted. Whatever the case, the RE-11s are more comfortable on the street.
The traction seems very good, but I have not really pushed it because it has not been to the track or AX.
However, I did notice that the car exhibits more yaw and lean with these tires. I am not exactly sure why. Perhaps they are gripping better and the body leans in response. I need to spend more time with the tires, they definitely have a different feel than the PS2s and RE05As, which are more similar to each other than the RE-11s...........
These are my initial impressions driving on the street and over some twisty cyn roads...
Wait till you get them broken in and on a track. These tires are outstanding.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
damon@tirerack.com
Or use this link:
damon@tirerack.com
Or use this link:
damon@tirerack.com
Or use this link:
RE-11's
I've been using these tires for DE's and absolutely love them!
http://www.youtube.com/watch?v=V0ngAOtkfvo
I like them! They are replacements for street driving. Previous tires were Toyo R888's, which lasted 3700 miles.
RE-11 Update
Tires have been heat cycled on the street multiple times and "pushed" on some twisties (HWY 84, Woodside to San Gregorio). About 350 miles or so since new. I commute 2 - 3 x week in my car.
Obs.
Obs.
- These tires ride significantly better than RE05As and PS2s - less road noise and cushier ride. Very noticeable.
- The feel compared to the 05As is quite different. The 11s don't have the pebble to pebble to expansion joint feedback as the 05As, which I missed at first. However, the ride is quite improved, so I have adjusted.
- The traction is excellent - caveat - street obs only.
- I run 33F/39R psi. I typically gain 4 psi when warm.
- I am still getting used to these tires, but I have noticed that they have dulled my lust for the spendy PS2s...........
Very Happy with RE-11s, Update
Quick update.
Have over 2 thousand miles on the tires now.
Did an AX awhile back and wow, what an improvement over the RE05As.
Tires have significantly better grip and slide in more forgiving manner.
Road noise is also noticeably lower than the 05As as well.
Winter rain is coming, and I look forward to seeing how they will perform in wet conditions.
Great tires for street and AX.
Quick update.
Winter rain is coming, and I look forward to seeing how they will perform in wet conditins.
Never tried PS2s at the track or AX.
RE-11s qualitatively have equivilant or superior grip.
I would like to try them back to back.
I do recall Damon at Tire Rack having some very positive comments about RE-11s in comparison to PS2s....you may wish to contact him.
The Re-11 has an interesting tread profile. It appears that it should do very well in good dry pavement. I wonder how they behave on the wet as it only has 2 longitudinal grooves and fewer sideways grooves.
It's interesting to note that TireRack lists these tires for the 997.1 but not for the 997.2 !?! They do not list the PS2s as OEM either !?!
One observation on tire weight:
RE-11 27lb F 32lb R
RE050A 24lb F 31lb R
PS2 22lb F 29lb R
RE-11 27lb F 32lb R
PS2 22lb F 29lb R
I also have the RE-11's on my 997. I've had P-Zero's and PS2's on my 997's and this for me is the best of the lot. Compared to the P-Zero/PS2 the RE-11 is much grippier, is quieter and is smoother-riding. No issues in the wet (and I drove them during the heavy downpour we had in the Bay Area a few weeks back). It's a great tire.
