Right side braking (caliper?) issue
![Question](https://www.6speedonline.com/forums/images/icons/icon5.gif)
Hi,
just curious if anyone had something like this ever before, when car is cold and before I step on brakes hard for a first time - sometimes, but not all/every time when I braking on regular way car jumps to the left. Looks like left front brake engages fully and right does not. if after that I hit brakes reasonably hard it cures and never happens again for a whole day, or sometimes even on a next day. But it has repeated often enough to be noticed. Steering wheel while this happens turns with enough force - if I keep my hand too loose it can actually jump off my grip. Brakes were flushed 2 weeks ago but issue remained - it started quite a while ago.
So after it is gone there are no side effects left at all - braking is equal on both sides, there is no difference in caliper temperatures, brake pads are worn on exact same progression, there is nothing that could show any issue.
No vibration while riding, acceleration is ok, alignment was done too, car behaves as perfect and as normal as it can be.
As it happened this morning I let it stay for an hour then tried it again - no, does not repeat. It only seems to happen when car was idle for some reasonably long time.
I called dealer today - they naturally never 'heard' if caliper may act like this (porsche calipers never fail?!) so they cannot say, naturally, if any work on such an issue will be covered by warranty by default or not (naturally) and my gut feeling is that if I give them my car with current half way worn pads and rotors they will fix actual problems then replace pads and rotors, bill me for a whole thing and blame it on pads or braking fluid, or similar.
So, what would be best approach for this? Just to wait it out until time will come to replace rotors and brake pads and if after that it will happen again - go to the dealer? Is there anything at all I could diagnose myself by taking caliper apart? Or is reason for such a problem would not be a caliper at all but my be some dirt particle somewhere in hydraulics lines?
Or is there anything on a right car side that may drip or condense on right brake disk and not a left one? I am not sure what to guess, it is quite weird.
Any ideas?
Any ideas?
will try to put new brake pads on and replace all i can on that sorry *** caliper - got this from suncoast:
99635108801 Front Brake Pad Damper 2 $18.68 $37.36
997C2C4FRPD Carrera Front Brake Pads 1 $130.33 $130.33
PadSet: 99735193903
987ScFrontKit Front Caliper Repair Kit 1 $23.25 $23.25
style: 95535296000
99907340201 Caliper Bolt 2
Do not see anything else I can put on and do not want to do rotors yet, old ones are worn but still have plenty of doe left on `em.
PadSet: 99735193903
style: 95535296000
any suggestions on how to fix that? spray its shaft with MAF cleaner perhaps while piston will be all the way down?
You can get a caliper rebuild kit...new piston seals ect. Maybe you have some dirty up there? Inspect the piston seals and clean with brake cleaner spray.
I do not envy you with the closed caliper on the standard Carrera. Best of luck and keep us posted.
![Smilie](https://www.6speedonline.com/forums/images/smilies/smile.gif)
I assume it will not ruin the car to have 350mm Brembos in front and stock in rear axle?
Or do people usually upgrade both rear and front? I am not sure why would anybody need bigger brakes at rear but it does not hurt to ask, I guess. Still it is highly unlikely will be needed, I also think now most likely it is dirt or brake dust build-up in a piston shaft. I should be able to clean it up.
Well, will do it next week as brake pads will arrive. I looked up procedure to work on those calipers - do not see anything difficult, really, seems exactly same as on any other car. Need to do the same on my Lexus before winter comes - rear pads on it are completely worn , hardly 3mm of pads left, but it`s so boooring... And I`m out of latex gloves.
Well, if that caliper will **** me off too bad I will cut it off and put new Brembo set there instead. I was thinking about it from the beginning but really do not need it, so it would be just a waste of money, similar to navigation install.
The front and rear brakes are designed to work together. There is a brake bias program that will allow your car to sit flatter under braking, instead of nose diving. I think that if you upgrade your brakes, it is best to do front and rear. Brembo's 350mm is a very nice brake system!
But, I honestly do not see much sense in doing that at all, definitely not this year. Next year, if I get big enough bonus in Q1 - may be, who knows. For now I am quite OK with what I have.
I am more concerned now about my driveway clearance - just 1 inch as I reach it. I was mentally all set on getting coilovers and now this bummer - seems like I'll not be able to get into my own garage if I get my car 1 inch lower.
nose lift is an another 2-3 grand I guess? I saw KW coilovers with a lift - $7K or so. hardly a wise thing to do but in Boston it would be damn handy. I guess I will have to wait on that.
My nose is all scraped already down below. Not even sure when, where and how.
heh, my wife screws my brain about new house for quite a while now but I want current one to get back to where it was in 2005 before we sell it - downpayment for new one has to come from somewhere and I didn`t figure out yet how to print my own money...
![hilarious](https://www.6speedonline.com/forums/images/smilies/smLach2.gif)
ECS Tuning - VW
08-20-2015 03:07 PM
