Battery maintainer wire door pass-thru
If you are away for a while and need to connect a battery maintainer to the cigarette lighter, where on the door do you feed the wire on a 997/997.2?
On 996s the bottom of the door weather stripping had a notch for that purpose, but that seems to be absent on the 997.2. Is there a good spot to avoid compressing the weather stripping permanently?
If you run your fingers down on the bottom of the door sill (and get your fingers all dirty), you'll feel a few places where there is some small indentation areas. I run mine in one of these and it seems fine.
I go either at the front or back of that hard plastic door sill with the hood releases. So far OK. I could see that if you left it stored for a long time without opening the doors, it could leave an impression but so far I see no signs of that.
COBB Tuning
03-29-2016 09:26 PM
RallyBird
10-07-2015 01:20 PM
COBB Tuning
09-09-2015 09:13 PM
