Replacing PCM with aftermarket NAV
I suspect that you'd lose the audio display line (center line) in the cluster under the tach (big deal eh?). I presume the fuel info (range to empty) would still be available in the center cluster, as well as avg mpg, but you'd lose the other mpg choices on the PCM.
To me, this 3rd party solution seems good for someone with no warranty left and a faulty PCM that is going to cost over $2400 to replace. OR, someone who just wants a better audio and nav system, with bluetooth etc. already provided.
Funny enough, the whole reason I started the process of the audio overhaul was due to my lack of satisfaction with a bluetooth interface integration that was a part of the purchase from the dealer. The guys that did my audio install were the same that do all the extra bluetooth, or nav install for my dealer so there was blessing grandfathered in and my CPO warranty wasn't affected.
Side note & project disclaimer: I'm notoriously OCD about my audio so it is very possible that ripping out the entire bose system and PCM and starting from scratch isn't for everyone, and not a thing to be undertaken lightly. All told, before the final components were left in the car, many different combinations and options were investigated and many a head was cracked against the wall in the pursuit (actually my head, several dozen times). At some point it has to be a labor of love or it will drive you absolutely b%$! f$!&#@!ing crazy. All the best.
-Alex
-Alex
thealexman,
Very clean looking installation. Use of the latest tech aftermarket touch screen units with everything seems to be a very viable alternative for 997.1 cars, like mine. Very interesting.
No problem Stan. The list is as follows: Kenwood 7140 head unit
Audison LRx 6.9 amp
Hertz Mille 165 System Speakers
JL Audio W6 subwoofers (2)
Soundwaves (who did my install) chose the appropriate size speakers from the Mille 165 line for the doors, dash, and rear. I need to find the box to get the exact size, as I don't recall off the top of my head what all was used. All told it was 7 speakers up front and 2 in the back plus the 2 subs. Hope this helps.
-Alex
Audison LRx 6.9 amp
-Alex
Thanks for the compliments guys. As soon as the current snowstorm cuts off I'll snap some pictures of the subwoofer install that they did. They did a wicked clean job, It's ported on the top instead of behind the seats like the bose unit. from an acoustical standpoint, it adds depth and air to the sound as it's not covered by the back seat. You're also catching reflection off the rear window. Pics will come soon...promise. haha
-Alex
-Alex
-Alex
-Alex
One other thing to consider, as Mdrobc13 touched on... In my opinion, the more features your PCM has at the outset of the process, the less viable going aftermarket becomes. My PCM was basically bare bones, so it was a very easy move to make. For those that have log books, multi-disc changers, etc. I would recommend sleeping on the idea for a few days longer than I did.
-Alex
p.s. it's sunny in Boston today, subwoofer pics coming up.
-Alex
Reputable Installers in Colorado
I am thinking of the PCM switchout and wanted to know if anyone had any direct and positive experience with Audio installers in the Colorado area (preferably Denver and preferably experience with a 997.1)?
Thanks!
Thanks!
I know this is an old thread. I also know I did this on my own car 5 years ago, but I can't remember. Now, I have another '06 C2S. I wish I had a better memory. Do you lose traction control on/off capability when you swap out the head unit for aftermarket?
Old Thread, but i'm in this position now and looking to replace the PCM in my 2007 Turbo. Had Bose unit.
Anyone have any updates or suggestions on replacements that include Navigation, BT, USB, BT Audio, Sirius/XM, CD?
Any suggestions on sponsors here that would be a good source of help?
I contacted Crutchfield... their response..
-So replacing the radio in this vehicle is not an easy task.
-We do not have an installation kit to make a new radio an easy fit.
-If you want to replace the radio you'll need to fabricate a custom install bracket and you may have to modify your existing dash panel.
-The wiring is also a challenge as you'll have to hardwire all the connections and bypass the Bose amp system by running new wire speaker wire to each speaker.
Check out this link below:
http://www.planet-9.com/cayman-boxst...vic-120bt.html
The link is information and a contact to get the Eurospeed adapter for Bose system. Loi Should be able to help you out and get you what you need to do the job. A lot of members on Planet 9 have done this mod.
ECS Tuning - VW
08-26-2015 01:07 PM
