Dension 500 Bluetooth help!
I have just finished installing my Dension 500 Gateway into my 997. The problem I am having is that I can't find anywhere to run the microphone into the ****pit of my car. I have pull the plastic out of the trunk, shined a flashlight in every nook and cranny but I can't find a hole that leads into the car. I have to be missing something. Anyone have advice that has installed this system? Thanks for the help!
This may help: https://www.6speedonline.com/forums/...o-g-rides.html
Look for a rubber grommets near the battery, may need to remove battery. When you find a good place to run your wire through use some safety wire or something similar to fish your microphone wire through with. Hope that helps.
In the front boot:
-Unplug the car's battery.
-Remove the bolt and bracket from the left side of the battery, which holds it in place.
-Slide the battery to the left.
-You should now see a round rubber grommet.
-Feed the foam end of the microphone through that rubber grommet.
Now inside the car:
-Raise the steering wheel.
-Look up, behind the pedals.
-You should see the foam end of the microphone wire.
From here, you have several choices in terms of routing and placing the mic.
CATTAMAN
Now inside the car:
CATTAMAN
Mark @ AIM Performance
46
08-29-2021 12:57 PM
