Independence of PCM 3 'Sound' settings
This is a question for '09, '10 owners.
The 'Sound' settings in PCM 3 Bass/Treble/Fade/Balance/Loudness are supposed to be independent from Source to Source. For example one can set Bass+ 2 in FM and Bass at zero in Disc. But... can you set Loudness in one source and not in others? I found that on my 2010 (non-Bose) PCM 3 if Loudness is set in one source, the system will set Loudness in all sources, and if one goes back and turns off Loudness in one source it will turn it off in all sources. It sounds to me like a software bug.
What happens in your (non-Bose or Bose) system?
Bose on 997.2 does not have loudness. Although it does have an "Audiophile" or Linear setting (opposite of Loudness probably) that is universal to all sources except Surround Discs. That setting is on the Options page of the Sound menu rather than the page with balance and eq.
Thanks for the confirmation. Clearly a software bug. Re its use... I'm still experimenting. I noticed that because I want loudness off in AM when I listen to traffic reports.
turbotuner20v
09-11-2015 12:02 PM
