I think it's time for a Battery Maintainer
I'll order the charger tomorrow. Before I buy a new battery... is there a way to test it? I mean, it's been fine up until the other day and that was after it sat for about a week and any trips were short. Saturday I drove for about an hour straight, turned it off at the beach, and it started right up and I drove an hour home. It's been fine since then. So it's able to build and hold a charge. I think I just let it sit too much in conjunction with too many short trips.
You can test it with a voltmeter (instead of taking it to Autozone or Pepboys). It should read between 12.4-12.7 volts (with the car off). If less, then most likely you will need a new battery.
Get the Ctek 3300. You can buy directly from Amazon with the cigarette lighter plug $10 extra.
volt meter
Yes and no. If you get a lower (below 12) reading on a fully charged battery you probably have a problem. However, you may get the 12.4+ static reading on an older/weaker battery but it drops immediately under load, indicating that your best days are over. This is why the load test rather than just a voltmeter is used.
$90,000 car....$100 battery replacement..$75 for a Porsche battery maintainer.
Cost of being stranded on a 4 yr old battery..priceless. Get the new battery and maintainer. Everyone spends big $$$ on everything for their car but the question remains about a battery?? I realize it isn't a "fun" upgrade but necessary like brake flushes and oil changes. Batteries usually let go at the worst of times
I say spring for the new battery, drive a couple times a week with some time behind the wheel.
+1, mine still works after 14 years of use.
cnebrask
10-03-2024 08:19 PM
04-28-2022 12:38 AM
