Carrera 997.2 noise from rear on bumps
#31
Sorry I haven't been able to post a picture of the piece of molding that had the loose clips (keep forgetting to charge my camera..but I will), but I can say that the noise seems to have gone away. The loose clips were on the carpeted piece that is right below the rear window, and on a right angle to the back carpeted deck, if that helps any.
#33
#35
DRP
#38
DRP
#39
I have the same problem...It sounds more plastic than metal...somewhere behind the rear seats... only had my 997.2 for 3M now and only 2700 Kms on the clock and the sound was there from day 10 or so... but I only heard it about 4~5 times so far and cannot isolate it.
#40
I have had the same problem. I get a glass metal tapping noise from the left rear corner of the car. I also get the thud sound you guys are hearing.
My 997 has been to the dealer about 8 times to try to fix the problem and to a porsche approved body shop maybe 5 times.
All the trims were removed and clips replaced. All the seals and rubber lubricated but still I get that annoying noise!
The body shop guys seem to think the tapping noise comes from bad welds under the rear tail lights, but I had that repaired and I still have the same noise coming from the same place.
Has anyone had this repaired? Its driving me crazy!
#41
I have never heard any noises like described, but here was a bracket/clamp for the exhaust/mufflers (can't recall exactly what) recall maybe a year ago for 997.2 - the dealer did mine when I came in for something else. Although I guess they would surely have checked that out?
#42
I became very frustrated with noise, vibration and harshness issues with my 997.2 base model Carrera
I am now the very happy owner of a 2010 M3 with Performance Pack with no such problems and sensational performance.
#43
It's not... Try the door
It's probably the door lock-latch thing... I had the same problem with all my P cars (4!!).
When you open your door and on the inside there is a belt buckle like (d shape) thing sticking out (from the car inner door panel not on the door). Unscrew, turn or adjust it into upright position, rescrew and spray some lubricants etc. and your sounds should go... It's looks to be an inherent issue with all porsches sports cars from the first 986 onwards as I've had the same problem with all my P sportscars since 2000.
I hope it works
I hope it works
#44
They are good cars, but not problem free - I've had 7 BMWs, 2 of them M3s and an M5, over the last 25 years and...keep it long enough and there will be something to deal with - it as a car afterall.
