Porsche 997 Battery Tray and Size Facts
All;
My factory battery went belly up and I researched a replacement here. One thing everyone should know is the battery tray (OEM) has three threaded holes and one open hole to accommodate multiple battery sizes. When I looked at replacements none were the exact size of the factory battery. The holes fix that. I had to run all the way home to look at it in the car.
I bought a Die Hard International battery at Sears ($135), of all the batteries I researched it had the best warranty and price of any of the batteries. I had to use the fourth hole (no threads) to fit it. I just removed the tray and used black tape to hold the nut in place. 15 minute swap.
FWIW - the sears international is a buck less than the Interstate MTP93 ($136.95) but has no wheres near the cca or warranty. It is 2# lighter.
Fly: I like your idea about taping the nut for installation. On the 93 I had to tap the outer hole for a longer hold down and installed a 10mm Wurth fastener.
I just installed an Odyssey battery as well as the machined aluminum Rennline battery bracket. It's a beautiful thing. Not that it matters, but the Odyssey is much less than 1/2 the weight of the stock one. Just on principle, having a 45 lb weight mounted high up in the car seems odd. And I've not had a problem with it maintaining a charge for 7-10 days.
Photos if you'd like. It's a very nice piece.
BTW, I previously had a Braille battery with a home-made bracket after my stock battery got a bit tired. I was not impressed - with either the battery or the service I received from the company - and would not recommend it.
All;
If you don't mind, can you post a pix of the Odyssey battery and the Rennline bracket? TIA.
