ECU & Disconnecting Battery
Old 03-08-2010 | 09:19 PM
michaeldantep's Avatar
michaeldantep has much to be proud ofmichaeldantep has much to be proud ofmichaeldantep has much to be proud ofmichaeldantep has much to be proud ofmichaeldantep has much to be proud ofmichaeldantep has much to be proud ofmichaeldantep has much to be proud ofmichaeldantep has much to be proud ofmichaeldantep has much to be proud of
I read somewhere that the Porsche ECUs are pretty delicate. I'm putting on the AWE CATs this week and I think there are two ways to have the ECU remap to the change. The quickest is to disconnect the battery (black first both to disconnect and reconnect from what I read), but this can lead to power spikes that can fry the ECU. Is it safer to just drive the car and eventually the ECU remaps? How long do you need to drive it? How many miles?
Old 03-08-2010 | 09:41 PM
Verde's Avatar
Verde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond repute
I don't believe that a simple disconnect and reconnect of the battery, to reset the ECU, puts anything in the electrical system at risk. So long as you're careful this is the way I'd proceed. The process will accelerate the 'learning' of the new exhaust behavior - enabling you to more quickly identify the change, if noticeable at all, from the previous setup.
Considering that these are street cars, designed to have batteries replaced, jumped for starting and all of the other electrical issues that come with long-term ownership, by people who are not necessarily as skilled as those on the Porsche factory race team, it's the path I would take - and do take every time I make a change.
Old 03-08-2010 | 09:46 PM
I was reading on another forum where a guy did the battery disconnect thing and the ECU went bad. He eventually took it to the dealership and wrote in his thread that the dealer said its fairly common for the ECU to go bad when changing a battery b/c of the spikes in power. However, I only read that once, so it's anecdotal information for now.
Old 03-08-2010 | 10:25 PM
Cattman's Avatar
Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !
I disconnect the negative terminal on my battery all the time, and it's never been a problem. A few hrs is all you'll need. Enjoy the AWE cats, they're terrific!
CATTMAN
Old 03-08-2010 | 11:03 PM
topspd's Avatar
topspd is infamous around these parts
Likewise, I've disconnected/reconnected my battery more than a half dozen times and no problems.
Old 03-09-2010 | 02:29 AM
ZoSo_DXB's Avatar
ZoSo_DXB is infamous around these parts
Same here, no problems at all besides the average mpg resetting.
Old 03-09-2010 | 12:41 PM
Axxlrod's Avatar
Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !
I disconnect the negative battery terminal every time I change a part of the intake/exhaust equation or whenever I changed anything with an airbag. Never a problem.
Old 04-29-2013 | 02:16 AM
wa1l1in's Avatar
wa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of light
is it neccesary to disconnect battery to "learn" new characteristics or will it do it on itself?
airbusdrvr
12-27-2015 08:43 PM
WheelsupZR1
10-20-2015 09:36 PM
10-02-2015 03:23 PM
G ///Mcgregor K
09-30-2015 02:46 PM
gliozzi
Bentley
09-28-2015 04:27 PM
Quick Reply: ECU & Disconnecting Battery
