Headlight "Auto" position
A new 911 can be equipped with a heated steering wheel, cooled seats, photochromic mirrors, headlights that turn into a bend and wipers that measure the rain, but apparently an automatic headlight switch like the type used on American cars for the last 30 years is out of the question...LOL
I am not sure if ECU has dedicated output with logical 'true' false' signals from sun sensor or if is it an analog one. If anyone has interest I guess it all can be done. I do not know why they did not do it on 997 as it was done for cayenne.
This might be an interesting third party mod for someone to manufacture. I'd buy one.
997 car has a sun sensor. Essentially all you need to do is to wire sun sensor input from ECU to relay and connect it to wire in light switch in the dashboard. I got stuck with wring part as I did not find for some reason that panel where sun sensor signal gets routed - it has to be on right side from PCM but somehow it was hidden and I lost interest to it in last couple of months. But it should be relatively easy thing to do.
To those who are brave enough to cut wires and have enough free time to solve this - here is a diagram, i hope i will be able to attach file to this message.
PS. and a page where sun sensor is shown. Good luck cutting.
For those who wants to have daylight feature - front fog lights a on wire on A5 contact of light switch and it seems when activated it uses a 64K Ohms resistor to contact A4.
I do not have stock of resistors anymore so cannot check it. if anyone is brave enough - try it and write up here if it will work or not - if you want your fog lights to be on all the time. But use your multitool first to double check what I saw prior to messing with wires!
So here is my standard argument against the auto-headlight feature on any car.... they don't work well enough and can reinforce bad habits.
First, they don't turn on or off quick enough.. so folks are driving well into a tunnel before their lights come one (whey they rely on the auto feature) rather than being on as they enter, which requires the driver or some predictive mechanism to know, 50 yards from now I'll need my headlights on. Same goes for off, though that isn't really a problem (going down the road a bit further with the lights on).
The bad habit is that of drivers not being aware of their headlight setting. If you start leaving it on auto - as many drivers do, and are contentious, its ok, but what happens if you forget that the last time you had the headlights on, you were in high-beam mode, and now your driving down the road irritating the crap out of everyone with your friggen high beams? (If the systems take care of this, then nevermind... I've never in my 24 years of driving, owned a car with the auto feature, so I'm not versed in the nuances of what it may do.... I'm just really unhappy with folks driving around with high-beams, oblivious to the world)
As for the high beams, Auto On doesn't have any impact on them at all. You could leave them on in any car regardless of how they lights turn on.
Just to add a voice from the other side - it's a sports car. Re old age - it helps old age, I'm told, to keep oneself sharp, being able to execute start/stop control checklists in complex machinery. I guess you do not fly airplanes - or are we also going to automate airplane checklists going forward?
My 997.2 has a Home light position. I do not even use that.
Otherwise I agree completely. Most of these 'missing' features are things I don't use on rental cars that have them, if they can be suppressed. It drives me nuts to have a car doing things automatically instead of at my command, whether it be shifting gears or anything else.
What do you do in such cars if they turn on the lights when you don't want them on?
Gary
Well, I use that position because the kerflunkte power company has upped the local line voltages to permit use of wind generators. As a result, we're going through four or five light bulbs a week and those in the garage door opener failed early. We need the lingering running lights to get into the house. (Can't fix them myself and too cheap to call a repairman to fix a light bulb until they drop the voltages again in Summer.)
Gary
Gary
But in general, we know that modern cars, and this one in particular, consume a lot Amps even when the car is shut off. An extra couple of minutes of high current further compounds the issue.
I do not use the LED DRLs either in general, as I can turn them off through the OBD. No need in the bright West daylight to have 2 LED bars on. I use them when driving in deep shadow canyon roads for safety though. Incidentally, the car is easily spotted and it does not need 2 bright LED bars to be singled out.
Gary: I commented in general. Knowing you, I know you have good reason to use that feature.
Sounds good on the face of it (or the tail as the case may be) but ask any fireman how much good it does to have very bright lights, flashing to boot, and a siren thrown in for good measure. I greatly suspect that something more than 90% of the "I never saw him" accidents are caused by drivers so distracted by extraneous matters that a mere light here or there means nothing.
The only useful way to avoid those accidents is the fixture behind your own steering wheel. Every thing else is as valuable as one of those stickers: "Baby on Board!" Or so it seems to my intuition. Would be interesting to acquire hard data some time, but no one is likely to offer grants examining questions when the answer might well go against the zeitgeist that way.
Gary
I think that system is more for women because if your a guy the car key will be in your pocket in which case it will slip out of the pocket and between the seat and center console or fall into the seat versus if your a women it stays in your purse....
I Want my one touch sunroof closure back!!!!!!
Folks if DRL's and the auto headlight option help eliminate just one accident then I don't understand how you can find fault with them. It still cracks me up that auto dimming mirrors are an option on the 997.
An option I did not pick on my ordered car. The flip prismatic mirror is a far better, simpler, solution. I have seen my share of failed photo-chromic mirrors and the ensued mess...
Sorry to hear about your misfortune with self dimming mirrors. I can only speak from my 40 years of driving and have never had such bad luck with this option. One less thing to distract me while driving.
