turn off radio/air etc..?
Old 04-13-2010 | 09:09 AM
P997S's Avatar
P997S is infamous around these partsP997S is infamous around these parts
Do you turn off your air and radio before turning off the car?
is it safe for the car to keep them on when you turn off the car?
Thanks!
Old 04-13-2010 | 09:11 AM
taylorcoleman's Avatar
taylorcoleman has a reputation beyond reputetaylorcoleman has a reputation beyond reputetaylorcoleman has a reputation beyond reputetaylorcoleman has a reputation beyond reputetaylorcoleman has a reputation beyond reputetaylorcoleman has a reputation beyond reputetaylorcoleman has a reputation beyond reputetaylorcoleman has a reputation beyond reputetaylorcoleman has a reputation beyond reputetaylorcoleman has a reputation beyond reputetaylorcoleman has a reputation beyond repute
I hear that your warranty will be voided if you don't turn off the air and radio before turning off the car...
Old 04-13-2010 | 09:12 AM
gloves's Avatar
gloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud of
Out of all of the cars that I have ever owned or my family had growing up, we never once turned off anything. My ex-GF mom turned stuff off and I never understood why. Unless someone jumps on here and say "Porsche says to turn it off", it doesnt matter and people will just go back and froth about it.
Old 04-13-2010 | 09:13 AM
gloves's Avatar
not even a smiley huh...
Old 04-13-2010 | 09:21 AM
No sir, not even a smiley.
Here, however, is a begrudging smiley
Old 04-13-2010 | 10:50 AM
michaeldantep's Avatar
michaeldantep has much to be proud ofmichaeldantep has much to be proud ofmichaeldantep has much to be proud ofmichaeldantep has much to be proud ofmichaeldantep has much to be proud ofmichaeldantep has much to be proud ofmichaeldantep has much to be proud ofmichaeldantep has much to be proud ofmichaeldantep has much to be proud of
It was an old-school belief with the older cars (like warming them up for an extended period), but I can't imagine it does any harm with new cars. I hope someone can verify one way or the other.
Old 04-13-2010 | 11:03 AM
stevepow's Avatar
stevepow is a glorious beacon of lightstevepow is a glorious beacon of lightstevepow is a glorious beacon of lightstevepow is a glorious beacon of lightstevepow is a glorious beacon of light
I'm sure the idea is less load on the starter/battery. Bet if you had to jump start the car, you'd see the point.
Old 04-13-2010 | 12:08 PM
gloves's Avatar
There is a point there. I can confirm that just from jumping cars in the past.
Old 04-13-2010 | 12:16 PM
PTParks's Avatar
PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !
Old habits die hard. I still turn off everything before shutting the car down. However, my wife seldom does so in her truck. More than a couple of times I've started her truck only to have my eardrums assaulted by the radio turned up LOUD .
Old 04-13-2010 | 12:36 PM
atr911's Avatar
atr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud of
My grandma unplugs the tv, stove, washer/dryer when she isn't using them. EVERYTHING gets unpluged when there's lightening!
Old 04-13-2010 | 12:54 PM
pcs's Avatar
pcs
pcs has a spectacular aura aboutpcs has a spectacular aura about
In my experience, most current cars disconnect everything but ignition when cranking - so there should be no extra load under normal starting. In the case of a jump start, most jumper cable connections do not supply enough power to start a car with a dead battery - I find that I usually have to let the dead battery charge a bit before cranking. In this case you do want to turn off all the accessories so that all of the current goes into the battery.
One feature that I do miss from the OEM Pioneer system in my Explorer is the automatic turning down of high volume levels when the car is restarted...
Old 04-13-2010 | 01:03 PM
P997S's Avatar
I used to turn everything off. Learned that from my mother. But with my 2010 I haven't been. It's kinda nice to start her up snd have the V1, radio(Bluetooth) and air all turn on as well. I just wanna make sure I am not damaging anything.
Old 04-13-2010 | 03:10 PM
jj123van's Avatar
jj123van is infamous around these parts
How about pumping the throttle few times before turning off the car? Would it void the warranty too if we don't do it?
Old 04-13-2010 | 04:37 PM
xXxGhotimanxXx's Avatar
xXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond repute
I leave my climate control on auto at 70F and never touch it. Well, sometimes I'll go down to 68F if I'm feeling warm. Other than that it stays where it's at. As for the radio, I never listen to it, it's always off. I don't have much occasion to drive the car, so I want to hear it when I'm in it.
J
Old 04-13-2010 | 06:45 PM
nelsonmx's Avatar
nelsonmx is infamous around these parts
The only reason I turn things off is so I don't have everything on when I get back in the car....Unless of course I'm just getting out for a few minutes......My wife, on the other hand leaves everything on, but I think she does that just to scare the bejeezes out of me when I get in her car. The best one is the radio at max volume! My heart ends up in my mouth!!
Last edited by nelsonmx; 04-13-2010 at 06:46 PM. Reason: Because I can't tipe, or spell.....
Quick Reply: turn off radio/air etc..?
