Maybe we will try CA instead...DME thoughts
Old 04-13-2010 | 02:31 PM
gloves's Avatar
gloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud of
So since it looks like Long Island is out I have a DME from a 2005 C2S in CA. Listed as having 49,889 miles.
http://www.cars.com/go/search/detail...19&CMP=usedInv
Let me know what you guys think. It was clearly driven with spirit! I just hope thats not a bad thing...
Old 04-13-2010 | 02:35 PM
ntlgnt1's Avatar
ntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud of
I would avoid this one, high mileage and bad DME. There will be better options just be patient.
Old 04-13-2010 | 02:40 PM
NorthVan's Avatar
The 6 overrev ranges are:
Range 1: 7300-7500 RPM
Range 2: 7500-7700 RPM
Range 3: 7700-7900 RPM
Range 4: 7900-8400 RPM
Range 5: 8400-9500 RPM
Range 6: 9500-11000 RPM
The average speed of the car was about 40 mph
Old 04-13-2010 | 02:44 PM
pureretro's Avatar
pureretro is infamous around these parts
Depends on price. The DME isn't bad. 7 ignitions in Range 4 is nothing.
Old 04-13-2010 | 02:45 PM
ntlgnt1's Avatar
Prove it!
Old 04-13-2010 | 02:48 PM
pcs's Avatar
pcs
pcs has a spectacular aura aboutpcs has a spectacular aura about
I work about fifteen minutes from the dealer - I'd be glad to take a look at it if that would be of any help to you.
Old 04-13-2010 | 02:58 PM
keninirvine's Avatar
keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !
Originally Posted by ntlgnt1
Prove it!
FWIW, those 7 ignitions at 8000 rpm took place in less than 2 hundredths of a second.
Old 04-13-2010 | 02:59 PM
ntlgnt1's Avatar
So you're saying damage can't be done in a split second?
Old 04-13-2010 | 03:01 PM
Nope. Just adding a little perspective.
Old 04-13-2010 | 03:06 PM
ntlgnt1's Avatar
But that's exactly my point. I hear so often on this forum it's only a fraction of a second, yada yada yada, but that is just opinion based. The fact is Porsche adds those ranges for a reason and the range 4 is getting into the physical limits of the engine. Long term damage can be done if only for a fraction of a second. It also speaks volumes as to how the car was cared for.
Old 04-13-2010 | 03:08 PM
gloves's Avatar
It would be nice. I have a lot more talking to do with the guy.
To the rest of the posts, I was on the fence about it. I knew the rev time was very very low but couldnt decide.
Old 04-13-2010 | 03:39 PM
pureretro's Avatar
Prove it!
I can't.
A number similar to this can still be CPO'ed (no 6'es), hence my expression of that opinion
Old 04-13-2010 | 03:42 PM
Ian_UK1's Avatar
Ian_UK1 is a splendid one to beholdIan_UK1 is a splendid one to beholdIan_UK1 is a splendid one to beholdIan_UK1 is a splendid one to beholdIan_UK1 is a splendid one to beholdIan_UK1 is a splendid one to beholdIan_UK1 is a splendid one to behold
Prove it!
Easy! - It's run for nearly another 600 hours since that overrev and is still running. Obviously seriously damaged the engine....
Old 04-13-2010 | 04:02 PM
crazycarlitos's Avatar
crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !
bad DME or not, i would personally avoid any 2005, unless it was CPOed and i am buying it from a P-dealer...
i understand the 'normal' avg speed should be around 30 mph
this car being around 40 mph suggests it was driven on a hwy often or the driver had a heavy right foot.
last overrevs (2+) was at roughly 690hours so the driver calmed down in the last 500 hours (or he finally learned how to drive properly )
Old 04-13-2010 | 04:09 PM
Ian_UK1's Avatar
Originally Posted by crazycarlitos
bad DME or not, i would personally avoid any 2005, unless it was CPOed and i am buying it from a P-dealer...)
Yeah, mine's been dreadful!
Quick Reply: Maybe we will try CA instead...DME thoughts
