Change oil/brake fluid after DE?
Rating: Thread Rating: 3 votes, 5.00 average.
Old 05-05-2010, 01:37 PM
monojohn's Avatar
monojohn is just really nicemonojohn is just really nicemonojohn is just really nicemonojohn is just really nice
Do you guys change your oil and brake fluid after every DE?
Old 05-05-2010, 01:39 PM
NorthVan's Avatar
Nope, I do oil every year, and the brake fluid as it is needed. Both are easy DIY jobs with the right tools.
Old 05-05-2010, 08:13 PM
keenan9's Avatar
keenan9 is infamous around these partskeenan9 is infamous around these parts
You will want to do a brake fluid change before every DE. It is not necessary to change oil before a DE.
Old 05-05-2010, 08:40 PM
atr911's Avatar
atr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud of
I have to say that it depends on your maintenance habbits.
If you track the car regularly, you should be changing the oil more frequently than the manufacturer recommends. (Porsche 15,000 mile recc is a joke) I think that every 8,000 miles is reasonable for a moderately hard driven car.
Brake fluid should be changed before every event. As far as I'm concerned, it's an expense of going to the track. I would also recommend having the brakes bled by a facility with the tools to activate the abs pump every 2 years.
Old 05-05-2010, 08:56 PM
RonCT's Avatar
RonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond repute
No and No. I do about 12 track days a year in Black / Red (Advanced / Instructor). I change the oil before my 1st DE of the year and same with brake fluid (Castrol SRF). I have zero issues and the 7000 miles a year I drive the car is more than reasonable even given the exercise on the track. That's the beauty of SRF - flush it once a year, no need to worry because it's that good.
Old 05-05-2010, 09:26 PM
cibergypsy's Avatar
cibergypsy is a jewel in the roughcibergypsy is a jewel in the roughcibergypsy is a jewel in the rough
My PCA region only asks for the brake fluid to have been changed within the last year.
Old 05-05-2010, 09:32 PM
atr911's Avatar
As usual RonCT, great info.
This is a good read on brake fluid:
http://www.stoptech.com/tech_info/wp...fluid_1a.shtml
Old 05-05-2010, 09:47 PM
RonCT's Avatar
When I used lesser fluid (ie: ATE 200 - same as blue but without the nasty dye) I had to bleed / flush often. And it still couldn't keep up. When I switched years ago to Castrol SRF (ultra-high dry and wet boiling points) it held up event after event. $74 a bottle, but well worth it because now I don't have to bleed / flush many times a year.
Old 05-05-2010, 10:20 PM
atr911's Avatar
I've just been reading up on SRF and think I'll switch to it next flush. Just need to find some here in Canada.
Old 05-06-2010, 07:31 AM
CAL's Avatar
CAL
CAL is offline
CAL is infamous around these parts
Thanks Ron, I will give the SRF a try this track season, have been using ATE.
Old 05-06-2010, 08:52 AM
monojohn's Avatar
Thanks for the thoughts.
I've been changing oil/Porsche brake fluid once a year for seasonal driving and about 6 DE days. Haven't had any issues on road or track. Just wondering if I was doing it right.
Old 05-06-2010, 01:36 PM
sin911's Avatar
sin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond repute
I've been using Motul RBF 660, it's been good for the last couple of events (4-5 events I think) but the pedal is starting to feel soft... I need to flush it again I believe.
Old 05-06-2010, 01:49 PM
NorthVan's Avatar
Sin, do you have steel braided brake lines? If not I highly recommend them, pedal feel is so much better.
Old 05-06-2010, 01:51 PM
sin911's Avatar
Yes sir, I do. I guess I work those brakes hard...
Old 05-06-2010, 01:54 PM
NorthVan's Avatar
then it is time to change the fluid
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
Quick Reply: Change oil/brake fluid after DE?
