Gearbox transmission oil change DIY
Somehow i could not find a link to DIY procedure in 2 minutes - if anybody knows please post here a link of where drain plus is located and how entire process works with recommended oil selections. I hope it got to be simple enough process to do.
Again, it is not about engine oil - it is about gearbox. Thanks!
Here you go, this is a 996 DIY, but things should be the pretty much the same.
http://www.renntech.org/forums/index...-instructions/
www.renntech.org/forums/index.php?/tutorials/article/64-manual-transmission-oil-change-instructions/
pshep138
09-01-2015 09:45 AM
LiquidElephant
08-27-2015 06:17 PM
