997.1 C2 to 997 Turbo front conversion questions.
I am in the process of completing the Turbo front end swap on a regular 997.1 C2, but have a little question regarding the front turn signals. Has anyone successfully been able to wire up the 997 turbo DRL, and LED turn signals up? What is involved, and is their a DIY floating around anywhere?
I know this may fall into the "LED" catagory, but Ive already done a search and nothing solid, or successful was found.
Thanks in advance.
Thanks in advance.
Search function HAS a few threads.....not sure IF any will help you,BUT....
Here is a couple of them....
https://www.6speedonline.com/forums/...onversion.html
https://www.6speedonline.com/forums/...-gen2-drl.html
Thanks. I have already read through those threads, and it doesnt really help.
This was a nice tidbit!
http://www.renntech.org/forums/index...nd-conversion/
I guess it is looking like you will need the newer control units and modified wiring harness....
Thanks !
^^ hunt for the threads where a
black 997.1 cab
red 997.1 c2
silver 997.1 c2
all did the turbo front end conversion, i am positive the owner of the black cab owner unloaded tons of info here on 6spd
black 997.1 cab
red 997.1 c2
silver 997.1 c2
oddjob142
08-19-2015 12:27 PM
PelicanParts.com
997 Turbo Vendor Classifieds
08-18-2015 03:41 PM
