Clearbra issues - Need removal issues
I've had my clearbra on the car for over two years, and I've noticed that there are small bubbling type marks on the side mirrors, and it is also peeling on one corner on the front bumper. The car is extremely low mileage (10k), and is garaged 100% of the time, so I am not too happy about it.
I want to remove the clear bra, but I have a couple questions in doing so. Should I be concerned about paint mis-match between the clear bra'd and non-protected area? Are there any things that I need to be aware and cautious of with the removal? I won't be doing it myself of course, but I want to know what to look out for.
You should not see any fading with the clearbra. It is generally resistant to this. The only thing you might "see" is a different type of water-resistance, for a while. Kind of like how you can see where your wipers sweep on a windshield. It will wear-off.
As for removal, if it's a 3M Clear Bra, use a hair dryer. Trust me, if you take it to installer for a simple removal (and not replacement) they will happily take your money but you could do it yourself.
3M Clear Bra's (and most others) come off easily with a hair dryer. Especially if it's already pulling up.
sometimes, portions of clear bra that "bubble" in small areas, can be saved with a slight pinhole. Also, some areas that are peeling- if it is only a very small section, can simply be cut away. Also, most reliable instal shops will guarantee the install and replace the panel/area that needs replacing.
Apply heat, pull
COBB Tuning
03-29-2016 09:26 PM
