Replace Drive Belt?
Replace Drive Belt?
My 2005 997S is approaching the 6-year mark since it's original delivery date. Even though I only have 38k miles, the owner's manual mentions the drive belt should be replaced every 6 years or 60k miles.
Has anyone done this yet? Should I go by 6 years and do it now or wait until I hit 60k miles?
About how much does this service run? I'm still using my local Porsche dealership for service, but know they will suggest it now - just want an unbiased opinion. Thanks!
Get it done now. It's a 5 year old++ piece of rubber in service every time you drive the car. Cheap insurance and an easy DIY. Took me 30 mins. Here's a nice diagram to show the belt loop configuration. Use a 1/2 in drive and 24mm socket head. The pulley is pretensioned for easy removal.
If your dealer takes care of you it should be no more than an hour labor and maybe $45 for the belt should you choose to have them do it.
You do not tighten...it has a tensioner!
Once installed,and you think it is on/done......go under your car and check the two bottom pulleys from underneath the car,just to make sure that the belt IS in the groove..if it is not PERFECTLY set in that groove you will shred the belt !
I shredded one by NOT checking this!
Hope that helps,
Stacy
Hope that helps,
Stacy
The 60K service at my local dealership for a 997.1 is $1450. You DFI guys have all the luck!
r_matt_6
10-08-2015 06:07 PM
60000, 997, belt, carrera, change, diagram, drive, loop, mile, photography, porsche, replace, replacement, serpentine, service
