Oil consumption / trouble in paradise?
+1 DFI, or any fuel-injection system should have no bearing on oil consumption whatsoever.
-1 The MFI systems from the early 911's used the engine oil for lubricating the mechanical injection pump. They didnt necessarly burn oil but they did leak from time to time.
My DFI engine uses no oil.
All - thanks for posting your experience with oil consumption; it's all very helpul.
As to the (paraphrasing here) "if some consume oil and some don't, isn't there a problem" question, well, good question. I'm not sure if there's something inherant in the design of the flat six that makes this such a pervasive problem, but it is a little frustrating that after 45 years of experience Porsche hasn't wresstled this "feature" down to the ground.
The good news is the 993 and later engines no longer leak like the early 911s. The bad news is that oil consumption seems to continue to be a variable from engine to engine. I had two 993s that were only a couple hundred serial numbers apart, and one used about a quart every 800 miles and the other used almost nothing. Sounds like it's the same with the 997...including the .2, which saw such a major redesign of the engine. Seems funny that it would continue to seem to be a crap shoot.
The Manual says:
(1.6 quarts/622 miles)
Some (most?) use less, and some outlier data points at zero.
It is worth reading through the manual about oil consumption as it can vary quite a bit depending on how the car is used.
Probably nothing random about the availability of those Velcro-oil-bags - I keep two loaded in the frunk just in case I need some on the road. My e39 M5 could drop over 1 quart on a 200 mile drive - probably due to diluted oil getting a good work out on a long drive, so I got used to keeping plenty on hand on the road.
up to 1.5 liters/1000 km
oil pressure
I'm new to Porsche and to this forum. I have had my 07 Carrera S for about 2 weeks now. I was concerned about my oil pressure and found this thread. Instead of having low pressure, I have high pressure and seems like high oil level. Wondering if this is a problem and if there's any easy way to remove a bit of oil.
In regards to your problem, I was wondering if you were able to check the pressure at higher revs.
Page 105 of the 2007 MY manual says:
"With the engine warmed up and running at a speed of 5000 rpm, the oil pressure should be approx. 3.5 bar or higher."
On another note, is that a Belgian Groenendahl you have in your pic? I have an all black half Malinois-half GSD and previously had a purebred Mal.
My consumption seems certainly on the high side - it looks to be using a quart every 6 to 700 miles. Hopefully that'll settle down. I've scheduled a change, along with the installation of full AWE exhaust, next week to get a better baseline with oil that I know the history of.
Yes, my dog (Lilly) is a 3-year-old Groenendael. She's a really great dog - not particularly good at riding in the Porsche as she gets car sick, but the best dog I've ever owned.
Right at 16,000 miles and my 09 997S is not buring oil anywhere like it use to. I started to notice less burning at around 12,000 miles and it has been better recently.
I estimate that around 6,000 miles 30ish track days in 2 years are pure track miles....5000 rpm and up.
I wish I knew how the first 12k miles were put on my car...but that's the exchange with getting a late-model used car...CPO or otherwise.
I'm hoping that, since my car gets a pretty full cycle of driving and regularly sees high revs and full load, consulption will slow down. Either way, the filler tube is pretty slick, so no big deal.
ECS Tuning - VW
09-08-2015 01:34 PM
ECS Tuning - VW
09-02-2015 01:47 PM
ECS Tuning - VW
09-02-2015 01:19 PM
