Dynamic Cornering Lights.
yes - if it has DCL, then it looks like there are two 'eyes' per headlight. easier to tell when you have cars with and without DCL side by side.
Porsche NA doesn't care. They said "talk to your dealer"
My dealer is not directly at fault - but they just keep saying "we'll add it on" each time.
I'm sick of this. Who knows what else is missing that isn't an option. ABS override? Brake fluid clamps?
How can they treat their customers who spend more than 100K, plus all those painful 60 days or so waiting for the car of their dreams like this. Buying a 911 and taking delivery should be a pleasurable experience ... this is far from one. Eric, I feel bad for you.
I paid cash. Not that this is important, but I walked in there today and dropped off a check for $115k. Paperwork took 7 minutes. It wasn't like they had to work for my deal.
It's incredible how badly this has gone.
If they can add that, it will be interesting - a few posts lately have been from people wanting to add those as well. If all the wiring is in place or addable will be the trick. Other than the lights, there's a control module that goes in the frunk...and the wiring. The lights (designed to be replaced) and module look like they should be easy enough.
I hope they can do it.
You're gonna have to go in there and say, "Hi, I'm Job, back again, and now I need you to put in my DCLs.
Does your VIN match that print out? At some point, after all this, you start to wonder what was going on with the car all that time it was in the US, but not at the dealer. Probably crazy talk, but I think you should look that car over very closely for any other missing or strange features.
VIN matches. Porsche NA did indeed confirm that PSE was meant to be on the car. I was curious if the dealer forgot to order it. So I'm sure the DCL option was also in the VIN association.
I agree. I'm starting to wonder what happened to my car as it sat in port for 3 weeks. Everything else is on the car though. I did a once-over after discovering the DCL's were missing..
I honestly think Porsche quality control on the assembly line is at fault here, though. Lead in the water or something dumbing down the workers. I'll keep you guys posted.
They should be able to add the lights and the exhaust. I would not do it though. I see no point in directional lights in a sports car and the STD exhaust is just fine. I hear it fine. The PSE has no performance advantage and if anything, with the moving vane, it's another gadget to break. I would seek though a reimbursement for the options I paid for and did not get.
This is just another perspective, that's all.
To the Op -
You will never miss what you never had .
The savings at this point makes the most sense.
I would echo the comment on the DCL. I had expected them to be similar to those on an M5 I had...turn the wheel and you get a significant change in headlight travel for the curve. Maybe mine aren't connected or calibrated correctly but I get very little travel when I look at them against my garage wall or at night going through a significant curve. I wouldn't order them again.
