Can't get into 1st gear at times.
I've had the same problem on my 2008 C4S during the colder months when it was my DD during the winter. Kind of scary on a wet/icy/snowy hill and the guy behind you is on your ***.
I usually just depress then re engage the clutch and it usually works or I panic and just try to force it which probably isn't the greatest idea. I should try the 2nd to 1st though.
I just recently traded in my s2000 for a 997. I've noticed it once in the 997 but also never noticed it in the s2000. I have noticed it in some of the other cars I've had in the past. I thought it was just me getting used to the new car.
Well that makes three of us on this thread that went to a 997 from an S2000. I love my car, but the S2000 had it made with that short throw shifter - all the car mags raved about how top-notch that gearbox was. I find the throws are a little longer in my 997 but not a big deal.
It is normal. It happened occasionally on my 997.1S since it was brand new off the showroom, and it happened mostly when the engine/transmission was cold when I first drove the car in the morning.
Just release the clutch and depress it again, and it should shift into the 1st at stop without problem.
Usually once the engine/transmission warmed up, the symptom would be gone.
Regards,
Regards,
Aisin is a major OEM tranmsission supplier, which has been supplying transmissions to many car companies around the world for decades.
Regards,
P.S. The 997 GT3 is still equipped with the Getrag gearbox.
And this whole thread has me a little concerned.
(I want the manual, the wife wants the PDK)
Most cars do that and not only Porsches or 997s. It is a synchro issue and it should not be forced. Just do this:
engage 2nd
back to N
release the clutch
press the clutch
engage 1st
That should do it.
Note: I noticed someone saying 'push harder on clutch and try get into 1st again'. Push harder on the clutch? The clutch must always be fully depressed to change gears. There's no such thing as harder... it MUST always be fully depressed, not just partially depressed. I suspect that a lot of improper shifting is going on out there.
engage 2nd
back to N
release the clutch
press the clutch
engage 1st
That should do it.
Misplaced concern. The Aisin tranny is better than the previous 996 Getrag.
But, is it a good transmission? In my case it's a genuine concern to know wether or not we have a good transmission, as I have a Carrera S. Can anyone in this forum illustrate me as to the quality of our Aisin transmissions? Thanks!
The Aisin tranny in the 997 is an excellent transmission. That does not mean it is unbreakable. These are not truck transmissions. They are designed for performance with the least mass. No sports cars trannies should be abused. I suspect many silly jocks who do not know better.
I don't think there's any reason for concern - my BMWs used to do this sometimes, but I rarely got caught. I most times go to 1st from 2nd when stopping even if I don't let the clutch out for 1st before stopping.
I always like to be in 1st when I come to a stop; ready to go. In neutral, if something happened - like a rear-ender - the car might roll, assuming you get hit hard enough to lose control of it. In 1st, it won't roll, and you're also ready to go instead of hunting for a gear at the green light.
Someone, a long time ago, when I first learned to shift, told me it was safest to always keep the car in gear. Never could think of a reason not to, so I have always tried to.
The Aisin tranny in the 997 is an excellent transmission. That does not mean it is unbreakable. These are not truck transmissions. They are designed for performance with the least mass. No sports cars trannies should be abused. I suspect many are by sllly jocks who do not know better.
Of course they shouldn't be expected to be unbreakable or abused. Fortunately for me, I am not one of the silly jocks who don't know better as no transmission on any car I've owned has been damaged by misuse, including the 915 on my '84 Targa which served me well for many tens of thousands of miles.
Thanks for putting my mind at ease by saying that our Aisin transmissions are excellent ones!
