Dealer said they flushed brake fluid without removing wheels
I took my 997.2 in for a low-mileage, one-year service + brake flush. The dealer performed the oil change, reset the service reminder (which was showing due in 2 days), and flushed the brake fluid. As I was waiting in the lounge, the service advisor came to me to inform that they didn't have to remove the wheels to flush the fluid. For those interested, I bought my 997.2 a year ago, but the car had sat at the dealer for almost a year so I decided to flush the fluid while I am at it.
He stated that they could flush the fluid from the brake lines running under the body hence no need to remove the wheels.
Is this true? Is it even possible?
IMHO, and this is from years of experience in the auto industry, I would not consider it a true and total flush unless the calipers were as well. To me, that is like dropping the pan on a A/T and leaving dirty fluid in the torque convertor. Kinda like showering and then putting on dirty underwear.
I would want ALL the brake fluid flushed, period. ESPECIALLY in the calipers.
Brake LINES?! Who messes with brake lines!? Maybe the service advisor needs more education.
Depends on your wheels, doesn't it? If they have lots of room to access the caliper bleed screws between the spokes there's no reason to remove them, AFAIK.
Exactly. There is no way to bleed the system without doing it through the calipers. There are no fittings on the brake lines otherwise, to me it sounds like the service manager didn't really know exactly what he was talking about, which is not unusual. Also no need to remove the wheels if it has a 5 spoke or like setup that has plenty of room to get to the bleeder screw. The procedure is specifically laid out in the work shop manuals.
How did you bleed the ABS circuit?
if it's not a warranty issue find an independent shop, not only will you save a grip of cash, you'll get better service. just my input. i took my car for a cat issue and they re-flashed my car back to stock. lucky my flash is embedded in the ecu and i have a remote to upload it
BULL**** dealers sometimes....You CAN "flush" fluid from the reservoir, but the TRUE way to bleed your system is by flushing it from EACH of the two bleeder valves in each caliper (total 8)
Dealer gave me a line about an ABS Circuit. I've never heard of ABS with brake fluid. Aren't they elecrontic circuits? Although you could bleed with out removing the wheels, it doesn't seem likely. Dealer wanted to charge $350 for the $100 job because of e "circuit"! Anyone have the skinny?
