Tire pressure question...
Old 02-10-2011, 06:39 PM
KYROCKS's Avatar
KYROCKS is infamous around these parts
Originally Posted by stacheman
I realize all of this, however the dealer set the pressures for me and so far so good. If I am not mistaken I just read in Excellence Magazine something about a GT3 recommended pressures being the same as I am running. I could be wrong as I don't have the magazine with me right now. I rarely exceed 160kms./hr. on the highways.
Mine is a 094SCab.
A GT3 has different OEM tires (R compound).
My 09 C4S cab pressures are 37F, 44R.
My 11 GT3 pressures are 29F, 31R.
Old 02-10-2011, 08:18 PM
mdrums's Avatar
mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !
Originally Posted by adias
Dangerously low pressures. You seem to value cushiness over safety. Be careful as you may end up with a blown tire at speed.
Not really...GT3's run 29/33....he will be around 34/37 hot with normal street driving.
At the track on a spring day I start out at 26/28
Old 02-10-2011, 09:16 PM
adias's Avatar
adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !
But 34/40 is the cold setting - street warm should be 37/43. Heck, it's his car and his life.
Also... why do people buy a sports car and then drop tire pressures so the thing runs like molasses?
Old 02-11-2011, 07:20 PM
mdrums's Avatar
actually his car stock settings is 33/39...the 34/40 did not come until the 2009 model.
At the track we run lower pressures for better traction. When most tires get above 40 psi in general they get slippery. I can tell at the track a 1-2psi difference. When my R888's get above 38 PSI they lose grip. they really like to be run at 35-37psi hot. My RA1's liked about 1-2psi more but there side wall was softer than R888's.
Porsche uses these higher PSI levels mostly for better fuel mileage. Also on the street a higher psi will help protect the rims on these skinny 19" side wall tires. The higher inflation doesn't have anything to do with tire performance grip. However at stock alignment setting and running a street tire the higher pressure does help the front tires from rolling over on the sidewall. The stock alignment setting are designed for people that do not know anything about performance driving.
04-28-2022 12:38 AM
RallyBird
10-07-2015 01:20 PM
horsepowerfarm
09-10-2015 06:09 PM
The Oss
08-24-2015 08:19 PM
Quick Reply: Tire pressure question...
