Replacing wheel center caps..DIY
Old 03-13-2011, 07:34 PM
ggregory's Avatar
ggregory is infamous around these parts
Has anyone swapped out their wheel center caps and can advise a simple way to do it?
I notice there are 5 clips on the back of the caps that hold it into the rim...how do you depress them so they'll pop out.
I'm sure it's not to difficult, I'd just prefer not scratching my caps up while trying to figure it out.
Image attached
Old 03-13-2011, 07:52 PM
away's Avatar
away is infamous around these parts
I played it safe and took the wheels off and removed the wire ring with needle nose pliers. Then it's simply a matter of tapping them out from the inside.
You might be able to pop them out with a screwdriver with the wheel on but I wouldn't take the chance of scratching anything.
Old 03-13-2011, 08:23 PM
KonaKai's Avatar
KonaKai has much to be proud ofKonaKai has much to be proud ofKonaKai has much to be proud ofKonaKai has much to be proud ofKonaKai has much to be proud ofKonaKai has much to be proud ofKonaKai has much to be proud ofKonaKai has much to be proud ofKonaKai has much to be proud ofKonaKai has much to be proud of
they are easy to remove from the wheels by using a wire coat hanger. you unwind the hanger and use the pointed ends, insert them in the 2 holes in the cap and gently pop out the caps.
the new ones go in a bit easier if you grease or vaseline them around the edges before popping them in.
Old 03-13-2011, 08:31 PM
Targa Tim's Avatar
Targa Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond repute
Originally Posted by konakai
they are easy to remove from the wheels by using a wire coat hanger. You unwind the hanger and use the pointed ends, insert them in the 2 holes in the cap and gently pop out the caps.
+1.
Old 03-13-2011, 09:03 PM
ggregory's Avatar
Awesome suggestion, thanks!
Thanks for the great suggestion, KonaKai.
Swapping out the caps took less than 2 minutes. Not a scratch, very easy.
Here's the coat hanger tool:
Old 03-14-2011, 01:35 AM
DMoore's Avatar
DMoore is a jewel in the roughDMoore is a jewel in the roughDMoore is a jewel in the roughDMoore is a jewel in the rough
Small allen wrench works nicely
Take a very small diameter allen wrench. Insert the short end, give a tug with the long end. Takes two seconds and works every time.
To reinstall, hold in place and smack smartly with the heel of your hand. Perfect.
DMoore
'10 P4S
'11 GTS
Old 03-14-2011, 06:42 AM
away's Avatar
oops, I forgot...I was removing my Champion Motorsport center caps which have no holes in them. That's why I took the wheels off, etc.
As others have said, the coat hanger routine works pefectly well for OEM caps. My apologies.
Old 03-14-2011, 08:12 AM
stevepow's Avatar
stevepow is a glorious beacon of lightstevepow is a glorious beacon of lightstevepow is a glorious beacon of lightstevepow is a glorious beacon of lightstevepow is a glorious beacon of light
Attachment 145925
This IS the way to do it with the OEM caps - you can also buy this tool from Porsche, but simple enough to make with a coat hanger.
Old 03-14-2011, 08:14 AM
utkinpol's Avatar
utkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond repute
take a wheel off, hit center cap from inside - it will jump out. big deal...
Old 03-14-2011, 12:52 PM
jhbrennan's Avatar
But make sure you put a hand in front or it will pop out onto the ground.
Old 03-14-2011, 01:23 PM
lowpue's Avatar
lowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud of
I created my own tool out of a coat hanger that works perfect....its essentially a 3 to 4 inch "U" shape with the ends bent up 90 degrees. The bent up ends are 1 cm or so long. The two ends line up into the holes and you just pull. The tool works great and I can pop out my Center caps real easily. I modeled my tool after this...but cost me nothing.
http://cgi.ebay.com/ebaymotors/Porsc...item564312191e
Old 03-14-2011, 01:59 PM
NC 997's Avatar
NC 997 has a brilliant futureNC 997 has a brilliant futureNC 997 has a brilliant futureNC 997 has a brilliant futureNC 997 has a brilliant futureNC 997 has a brilliant futureNC 997 has a brilliant futureNC 997 has a brilliant futureNC 997 has a brilliant futureNC 997 has a brilliant futureNC 997 has a brilliant future
I assume that when you re-installed the caps you aligned the pointy end of the Porsche 'badge' so it points toward the valve stem.. like they do from the factory..
Old 01-25-2014, 02:19 AM
W211's Avatar
W211 is infamous around these parts
My centre wheel caps got pretty beaten up all these years, took delivery in 2006 August, summer and winter, one set of wheels, finally got them changed with the homemade hanger tool.
Thanks for all the tips here.
Name:	Screen Shot 2014-01-25 at 1.15.14 AM.png
Old 01-25-2014, 06:03 AM
Mlv_250's Avatar
Mlv_250 is infamous around these parts
Good info thanks. I am planning to have mine replaced soon but I am trying to locate center caps that are blanks without any Porsche logo. Has anyone come across blank center caps to match 19" Turbo Wheels? Here is a pix of a wheel that I have on my car.
Thanks.
Old 01-25-2014, 10:51 AM
autobahn it's Avatar
autobahn it has a spectacular aura aboutautobahn it has a spectacular aura aboutautobahn it has a spectacular aura about
The handle of a hammer will do the trick, if rims are off the car (so you can get to the caps from the back side).
The wooden handle offers a nice dead blow. I've always thought anything metal used, could cause dents in the
caps or crack a plastic cap. I nice smack with that hammers handle will pop the caps right out.
Quick Reply: Replacing wheel center caps..DIY
