Pilot Super Sport vs Pilot Sport PS2 ... newer model seems heavier
Long thread/debate in the TT secton on PSS v. PS2's. Link below. Thought you guys might be interested.
https://www.6speedonline.com/forums/...007-turbo.html
Very disappointed on the PSS wear pattern
2010 Porsche 911 GT3
Front chamber -2.1 0 toe
Rear chamber -1.9 Very min toe in (don't know the exact number)
New Michelin Pilot Super Sport
Cold tire pressure on track: Front 30, rear 31. Hot tire pressure on track: front 37, rear 39 psi
5 track days later:
2 days at Streets of Willow
2 days at Willow Springs Race Way
1 day at California autoclub speedway inner course
All 4 tires outer were flat where as the inner are still 80% remaining. One of the rear has corded outer.
My take is the wall is weak and can't handle hard cornering. Other than the wear, I am happy with how the tires performed.
Does anyone have any track experience with them?
5 track days later:
5 track days later:
5 track days later:
I though the tires were suppose to be 36-38F and 44-46R hot or there abouts. It may be that the lower pressures let the side walls flex more which increased the wear rates. Of course, this is speculation.
It's funny you said that. I had my best lap time with front and rear in the low 40's (un-intended because the prev session was wet and cold with tire pressures in the high 30's; and during the subsequent session the pressure went up to 40's because the track had dried up and ambient temp was warmer) with a passenger inside. Then, I dropped my tire pressure to where I thought they should be and I was little less than a second slower without a passenger. Unfortunately this occured during the 5th track day where one of the rear outer corded.
I may have to get another set and test out your idea. Expensive tuitions that I wish I could've avoided. Other than the uneven wear, I really like them. I have emailed Michelin engineers and hopefully, they can provide me an answer.
Thanks for the info
Thanks for the info
In my 997 non-s, 18" MPSS I start at 29/31 cold and during the day zero in on 34/36 hot. My first run I usually come off at around 37/40 hot.
Over 40/44 hot I'm all over the track as the car floats and has no grip.
i have LCA to increase camber.
Just my experience. I have about 8 days on tires and they still look good. Only an intermediate driver however.
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
P0rsch3's PS2s
P0rsch3, Thanks for your comment. It is what I was thinking and the Potenza's are killing me. How long did your PS2's last? Can you tell a big difference on wet pavement?
No issues at all with the PSS in regards to town / freeway / canyon driving. They are an excellent tire even on wet, quite predictable and grippy. For my driving, I really need a predictable tire. IMHO, anything less than PS2 or PSS just does not work as well on the 911. Some may disagree on that, it's just my personal experience.
P0rsch3, I am going to try them. Tirerack has a sale right now. I am running 18s on my 01 Cab and the Dunlops didn't last and the rear of these set only lasted 7k. The dealer always gives me flak for having newer tires on the rear and older in the front so I am going to replace all 4 this time and see how long my rears last. I wish I had the canyons - there is not a curve they don't like
That's just the way it is with a pcar. they are not made for 'economy' of tires, they are made to drive & handle. You could put some lame, hard tires on it to save money on rear tire changes, but then you totally blow any hope of good ride or - most important - handling. Consider it "price of ownership" . heh.
Oh and if you have not had an alignment lately, like say 2 years, then get one when you put the new tires on. I have my alignment done every 2 years. I had my four 19" PSS installed with alignment for $1650 out the door at a local shop, if that helps, your's should be less expensive due to the 18" size- Which is the proper size for your pcar.
If you want to add a bit of snap to your ride, buy wheel spacers and longer bolts for the wheels- Automotion.com has them, you'll need 15mm spacers in the rear and 7mm up front. you can go as big as 18mm rear and 15mm front (IIRC), but the 7mm front / 15mm rear is a good safe choice.
Makes the car look beefier and you'll notice a tad bit better turn-in on corners. Call automotion and they will set you up with the correct H&R wheel spacers and longer wheel bolts.
You are going to enjoy the tires- report back and let me know what you think.
The MPSS went on my Porsche today. It is actually a bit noisy and it is weird because it is not a constant sound like the one you get when the tires wear out. I don't know if it is because they are brand new or what...I am hoping. thanks
