20's for the street 18's for the track
Old 03-16-2011, 07:14 PM
Thomas9181's Avatar
Thomas9181 is infamous around these partsThomas9181 is infamous around these parts
I have CCW's 18x9 and 18x12 on a 997S that is PASM lowered (10mm) that could easily go to 20mm lowered or more without rubbing. The 18's offer you so much more in tire selection and the 9 and 12 inch widths allow for many tires size options. The "typical" size for these wheels tend to be 245/35/18 and 315/30/28 or 245/40/18 and 295/30/18 with Hoosiers (if you keep the Porsche spec of larger in rear and smaller diameter in front) or 245/40/18 and 305/35/18 with R888 or RA1's (which I run). 20" wheels will just cost you and you will never get any benefit they might offer (unless you are a pro..................).
Old 03-16-2011, 08:59 PM
NorthVan's Avatar
Originally Posted by lowpue
Just to clarify, 5mm spacers with 18" OEM wheels and no Problems? I also have the Sport PASM with 20mm lowering? Wonder if that will cause problems? In any case, My wife will kill me when she finds out I will be buying another set of wheels/tires for the track....that means I will have a summer, a winter and track set. How will I explain
No problem at all, I have used 15 mm in the rear and 7 mm in the front with OEM 19" wheels, and lowered to ROW height without any issues at all. Just make sure you have the proper bolts (longer)
Old 03-16-2011, 10:00 PM
lowpue's Avatar
lowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud of
Yep thanks....I got OEM spacers and Bolts....
ModBargains
991 Vendor Classifieds
10-13-2015 03:57 PM
ModBargains
991 Turbo Vendor Classifieds
10-13-2015 03:56 PM
WheelB
09-03-2015 10:26 AM
ECS Tuning - VW
09-03-2015 09:43 AM
Quick Reply: 20's for the street 18's for the track
