Cup Holder Problem
MrLister
Two cap screws hold the assembly in place. You can access them easily with the glove box door open.
The 3D printer fix seems like the most cost effective solution to fixing a broken catch latch. Does anyone know if the part is available?
+ 1 on lubricating the locking mechanism. Fixed my that way a few years back and have not had any issues since and my cup is pushing 8 yrs old amd I use it regularly. Used Krytox perminant lub. Expensive but worth every penny if you don't want to have to lub something over and over again.
Guys I searched over on Planet-9 and couldn't find it, honest. Anyone have the link or the tip?
I will probably confuse the issue more than help .... but I once put in a soft drink bottle that had a slender middle. Some little piece/flap in the porsche cup holder opened on the slender part of the bottle and jammed the bottle in. When I forced the bottle out, the little piece (sorry no pics) came flying out, broke. I looked at the other drink holder, and the little piece had already been removed by the PO. It is a small 1 inch long piece that is pushed down when you put a cup in. But if the center of the cup/bottle is slender, the little piece can re-open and it will not point upwards, thus your bottle becomes jammed. Since both of these little pieces are now taken off, my cup holders work perfect. So if this makes any sense, remove those small flaps found in your open cup holders, one inside each cup holder.
Kicking this dead horse
Ok so I've had this problem for about a year and my solution was just not using it. However, I designed that annoying pin on sketchup to exact specs and so close to producing these little things that will save you all $$ and headaches. One problem, computer glitches are preventing me from calibrating my 3D printer to print such a small part. Anyone with a 3D printer want to give it a try? I'll gladly pay for shipping and a few bucks for the time/PLA. I've attached the sketchup and DAE files for anyone who wants to give it shot.
Cup holder problem
This might fixed the problem. Located the center piece, open the right cup holder and put your finger on the right side of the center piece and try to push a tiny lever to re-set the mechanism.
