Clutch problem
Clutch problem
UPDATE: 6-21-11
took it to the dealer. confirmed that it's the clutch.. they said the flywheel is fine, tho.
Got a killer deal on the parts and labor to ease the pain. =)
i shifted from 1st to 2nd at 7k rpm and heard a soft 'pop'..
next thing i know, the clutch feels 'weak'.
now the clutch lets out (upto half) normally then it comes up slowly the rest of the way.. like the spring action is gone.
it's hard to put it in 1st gear from a stop. and even 2nd gear is not easy.
i managed to drive it home (mostly highway)
btw, i had a small issue previously - clutch vibration
https://www.6speedonline.com/forums/...placement.html
and now contemplating my next move.
1- should i take it to the dealer 1st to see what the exact problem is? take the car knowing they won't fix it under warranty since its 'wear and tear' part?
2- or should i just take it to a place like GMG racing and let them do whatever they suggest?
3- or buy the parts (not sure which parts to get, tho.. the clutch assembly? the flywheel? or back pressure plate..?) and take it to a local indy??
suggestions, advices, and feedback are all welcome and encouraged.
thx in adv !
thx in adv !
I will regret this... but to decide your next step... how experienced (as absolute fact) are you in operating a clutch and manual shifter? Many brag about their proficiency, but from what I see on autox and other car events, that is far from reality. If you are less than perfect in manual shifting, stay with OEM parts.
i am just trying to figure out if the problem is limited to the backpressure plate or the whole clutch assembly.
any recommendation to local indy would also be appreciated
Crazy Carlitos,
Not sure where exactly in SoCal you are. I'm in Newport Beach.
My local Indy is a factory trained Porsche Master Mechanic with more than 15 years experience. He runs a small shop on Birch Street. I use him all the time.
European Car Specialist
http://europeancarspecialist.net/OC_...od_Prices.html
Reviews here:
http://www.yelp.com/biz/european-car...-newport-beach
Let me know if you're in a different area and I might be able to recommend others also.
Reviews here:
Crazy Carlitos,
Reviews here:
Reviews here:
if u got any recommendation in the area, i'd appreciate it !
i can still depress the clutch and change gears.. it just feels like the clutch lost the action in the springs..
i know its clutch-related.. but not 100% sure if the clutch itself is the problem.
also, should i have it towed or should is ok to drive it to the shop? the car is driveable but i am afraid i might damage the parts more..
will do.
any thoughts on the flywheel ?
i.e. does the symtoms sound like DM flywheel issue?
from this thread, it appears to be the pressure plate..
https://www.6speedonline.com/forums/...into-gear.html
Did the SA offer any info about WHY the clutch failed prematurely?
jaehoppa
10-22-2015 09:17 PM
ECS Tuning - VW
09-03-2015 09:43 AM
