997.2S oil consumption
Old 08-03-2011, 10:44 AM
chance6's Avatar
chance6 is a splendid one to beholdchance6 is a splendid one to beholdchance6 is a splendid one to beholdchance6 is a splendid one to beholdchance6 is a splendid one to beholdchance6 is a splendid one to behold
Hi all, I've put about 3000 miles on my (new to me) 997.2S, and it's close to 8000 miles total at this point. It's been really hot here in the midwest (about 2.5 weeks straight of 95+ deg temps) and I recently got the "check engine oil level" warning light...to which I added about 1 quart of 0W-40. I know it's normal to consume oil, especially early in the engine's life, but...
is adding about 1.5 quarts over 3000 miles normal ? Mostly highway driving...
Old 08-03-2011, 10:45 AM
chance6's Avatar
and P.S., I know the oil was full when I got the car...granted, I did go probably monthly in checking the oil, but this was the first warning I got...
chance6's Avatar
...and, it has been only about 2.5 months since getting the car.
Old 08-03-2011, 10:59 AM
tjp's Avatar
tjp
tjp is offline
tjp is infamous around these parts
I have had by 2011 997.2 c2S manual for ~4 months and have put on ~4,000 miles and have not had to add any oil, still about 1/2 way down on the electronic dip stick indicator.
Old 08-03-2011, 11:14 AM
RED HORSE's Avatar
RED HORSE is infamous around these parts
It took mine about 15,000 miles before it stopped using oil.. Drive it aggressive for a couple of thousand miles and I'll bet you will be dandy.
Old 08-03-2011, 11:30 AM
chance6's Avatar
Thanks guys...my 3.6 Carrera used a little oil, but I got that one when it had 10k miles on it. I know this 997.2S sat around and was only driven about 2500 miles per year before I got it. I have the impression it needs to be driven aggressively, AND it has been so humid and hot that I bet I'm burning off all the excess 'crap' in the oil with highway driving.
Old 08-03-2011, 11:57 AM
JohnM's Avatar
JohnM has much to be proud ofJohnM has much to be proud ofJohnM has much to be proud ofJohnM has much to be proud ofJohnM has much to be proud ofJohnM has much to be proud ofJohnM has much to be proud ofJohnM has much to be proud ofJohnM has much to be proud of
So far, I have only dropped "one bar" over $5,000 miles. It seems like it did so at the first 5K. Over the last 2 oil changes, it has not dropped. I have never had to add any oil.
Of course, if I park the car on a hill, nose down and to the right, it still fills the parking lot with a huge cloud of burnt oil-smoke! When I first got the car, I was losing oil in a hurry that way! I think there is an oil-pickup in that corner of the pan......
Old 08-03-2011, 07:48 PM
Scoper's Avatar
Scoper has a spectacular aura aboutScoper has a spectacular aura aboutScoper has a spectacular aura about
Search this forum and you'll find lots of oil consumption threads, especially for 997.2. I have added 3 quarts since I got the car new in 2010 March, at 8000 miles now. (One quart since oil change at beginning of this year) glug glug glug. I check oil level at every gas fill up.
Old 08-04-2011, 08:05 AM
chance6's Avatar
ok Scoper, sounds like my engine is not unusual...!! I suspect that once I get into the 15000 mile range she may need a little less...
Old 08-04-2011, 08:54 AM
lonewolfdj's Avatar
lonewolfdj has a spectacular aura aboutlonewolfdj has a spectacular aura about
I got mine at 8,800 miles and I'm at 14,000. I've added 2.5 quarts. It had an oil change just before I picked it up.
Old 08-04-2011, 09:23 AM
911cv's Avatar
911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold
I had to add oil this past weekend as well.
I change my own oil and I am always cautious not to add too much oil. I always check my oil at the end of an oil change and it always reads to the top bar. Now, there is some error associated with the electronic measurement. Even though it was reading at the top bar, it may have been .01qt above the limit to get this reading. Thus, burning .01 qt of oil may have dropped it to the middle bar. My point is that in theory, there is only .41qt (I believe each bar is .4qt -- don't have my owner's manual in front of me) between the highest bar and the "Add Engine Oil" indicator level (the lowest bar out of the 3 segments---not the very bottom Oh s***! bar).
So, burning .41qt, especially if you drive your car with some sort of enthusiasm during the Summer, is definitely not unheard of.
Old 08-04-2011, 10:37 AM
ScooterP's Avatar
ScooterP is just really niceScooterP is just really niceScooterP is just really niceScooterP is just really nice
Perfectly normal. My C4S burned about the same amount over 3,000 miles and I bought it when it had 7,200 miles on it.
Old 08-04-2011, 11:07 AM
adias's Avatar
adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !
My car ('10 S) burns no oil. Some flat6s burn oil, others do not. I think that a few do not burn oil, a few burn 1qt/600 miles, and the majority burns some oil, say 1qt/2000 miles. The high burners and the no burners make up the tails of the distribution.
Old 08-04-2011, 02:34 PM
Minok's Avatar
Minok has a spectacular aura aboutMinok has a spectacular aura about
I add a quart about every 1,600 miles.
You could go as high as adding a quart every 700 miles and still be within the allowed Porsche spec.
1.5 every 3k is fine.
Old 08-04-2011, 03:21 PM
Gpjli's Avatar
Gpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud of
Drive it and check the oil every once in a while. You will determine how much oil your motor uses. It matters not to you how much oil other folks motors use. Find YOUR baseline and add if and when necessary. Great car. Enjoy it.
Quick Reply: 997.2S oil consumption
