Scraping the bottom: big problem?
the bottom is plastic. I scraped mine the first day I got my car, and the following week, I just threw some touch up paint over it. It looks pretty good! When it gets worse, I figure I'll just replace it with an Aerokit bumper.
I even learned to assess the angle of a driveway to determine beforehand if I can navigate it without scraping. If it looks too steep, I usually find another way in or park outside, etc. Also, putting the PASM to sport helps a bit.
Thanks for the tip regarding using the PASM sport setting!
mine is also scraped beyond repair. mechanic even asked me if I hit curbs all the time - no, just a lot of steep driveways. and al that with high sitting stock front bumper, it is not even an option to put on low sitting aerokit. it is just the way it is, nothing can be done about it.
I just actually bought mine (07 Carrera S, 16000 miles) two weeks ago--haven't personally scraped the bottom, but there's some pretty impressive (and fairly fresh-looking) chewing of the underside of the front bumper that wasn't visible until the car was up on the rack, with a couple missing bolts. Happily, the dealership is taking care of this for me. My already healthy respect for parking blocks and curbs has now gone up a few notches.
if your car does not know how to drop right side passenger mirrow to show rear right side curb when you engage rear gear - buy mods4cars little box so you would have this function. pretty priceless thing to have if you have no one to assist you with parking in the city.
My driveway doesn't look that bad but all the scrapes I have are from going in and out of it. It's a 2008 Carrera S.
Backing straight out and pulling straight in seems to work the best but I still drag the flap. Taking it at an angle tears up the black plastic on the corners. I suppose that would work better if the obstacle was narrower.
Thanks for mentioning the PASM. I asked about it elsewhere and was told it would not make a difference by some and that it would lower the car and make it worse by others. It's worth a try. What about raising it 1/2"?
PASM doesn't lower the car, just stiffens the suspension. Cars equipped with PASM do have a lower factory ride height though.
It's a stock feature to be able to have the passenger mirror tip town in reverse if you want it to, just read the manual to see how to program it to do this when the mirror switch is turned to the passenger side.
You can avoid accidentally bumping parking cubs by backing into spits that have them. The rear bumper is tall enough to pass over them and the rear tires will be the only thing that bumps them unless you're running a deep sump oil pan. No need to buy and install any type of warning device that has to be spliced into your car's wiring.
I don't need the mirror feature or have problems
with concrete bumpers, I avoid them.
Thanks for the clarification on PASM. The descriptions all ambiguously said it lowers the suspension which I figured was incorrect
I'll try this technique when I return. Otherwise, I'll be paying someone to do a little concrete grinding
http://www.bridjit.com
I freaked the first time I heard the scraping noise but settled down when I climbed under and saw it was just the rubber strip. I have rubber curb ramps for getting into my driveway. We have "soft curbs" but it still would rub. Added bonus was I figured out the even my wife's Explorer SUV was rubbing on its rubber flap too until I added the rubber curb ramp
manfred@loma_wheels
09-02-2015 11:22 AM
ECS Tuning - VW
09-02-2015 09:03 AM
