brake caliper paint info
Hello everyone,
I need some opinions on rust oleum brake caliper paint... any one used this product before??
whats the difference between G2 caliper paint and the rust oleum spray..
thanks guys
thanks guys
The G2 is a brush on paint that comes in a kit with a small brush, brake cleaner, etc. With liquid paint, as opposed to spray paint, you'll have much less masking to do and can worry less about overspray. Additionally, the G-2 liquid paint is pretty thick and IIRC only requires one coat for an even finish. I used it and got great results.
Don't forget to get some replacement caliper stickers!
thanks guys, I used g2 before, but for me I think the spray paint is easier, but my concern was if its going to be the same durability, the G2 I think looks great, how do you guys do the stickers, paint caliper and then put the sticker and you put some clear coat on top of the sticker??
How do you match the factory red or the yellow colors ? My C2 Turbo has a small nick that i would like to fix it ?
Any feed back on fixing that, primer and paint or just 2-3 layers of paint ?
I decided to use spray paint because I wanted to avoid the "heavy" look that I had seen with using G-2. This may have been from not applying it correctly.
I used a high temp silver with red caliper stickers. A couple of coats of silver, applied the stickers, a couple of coats of high temp clear. I really like how they came out.
Best,
Matt
Best,
Matt
04-28-2022 12:38 AM
ECS Tuning - VW
08-20-2015 03:07 PM
