Water pump- a DIY project?
It's been confirmed that I need a new water pump..
I can get it from Suncoast for $219 plus the coolant. Is this something I wanna do myself or pay indy $400?
Any instructions you guys know of on the site?
Thanks!!
Thanks!!
Water Pump
Looks like you'll need a hoist and engine support:
http://www.renntech.org/forums/topic...ement-on-997s/
Make sure you remember to get the gasket for the water pump. Since you are at it, you might want to check or upgrade to the low temp thermostat.
As with the rest, i suggest getting someone familiar to do it. Even though it looks easy, i would rather have a piece of mind by getting someone with the proper tools to fix it.
Good luck..!
Good luck..!
Even though it may look like an easy job and very well may be.....my worry would be bleeding the cooling system of any air that gets in the lines,that to me is crucial,especially with having the radiators in the front of the car!
IF all you are going to save is a couple of hundred dollars....IMO,NOT worth it!
Cheers,
Stacy
Cheers,
Stacy
Decisions,decisions,
Good luck..!
Good luck..!
What are the benefits of the lower temp thermostat?
Normally the factory thermostat opens at approximately 185F thereabouts, the lower temp version opens at 160F which allows the coolant to cool the system faster.
For me personally, it is a precaution thing hence i just installed it.
Well, its not really a $400 savings unless you really had nothing better to do the entire day it will take you to get that done.
996 Water Pump Replacement
Although this is not a 997, it gives you a pretty good idea of what is involved:
http://www.youtube.com/watch?v=h0L0klF8lVo
This is why you should not remove the thermostat, and or replace it with one that was not intended for the application.
