GTS changed out rotors and brake pads today
Ok after a few track days and a auto-X it was time to change out the front rotors and pads. This last weekend at Hallett my brake sensor light came on, it was at the end of the day so seemed like a good time to call it a day. When I started the car back up to drive it home, the light was off? then while driving down the hwy it came on again, then after stoping and restarting it was off?? so today I changed out the rotors and pads. It appears that the sensors ground out on the rotor but there was enough pad that they didn't stay grounded. so I left them in and just changed out the rotors and pads. wasn't too bad had to take the post off the old rotor and re-install on the new rotors (center locks) that was the only slow down from a normal change out. So after a couple of hours and a couple of cups of coffee all is good!!
I didn't torque them, I really wasn't ready for that part, didn't know those were attached to the rotor. After checking noticed that Suncoast sells the hardware kits and suggest that they be replaced with the rotors? I would bet that specs would be in the hardware kit. Looks like I will order a couple of kits and change them out, as for now I don't see why old ones would not work.
you got more miles out of yours than I did, I have a little of 7500 miles on the car.
The only car I had, that had center locks on it, was a formula ford and the pins were on the hub not the rotors. The pads were bad enough I didn't want to wait to order a set, I just re-installed the old ones,( 5 months old). The next set of rotors I think I will order the pins also. Should be next summer though, with the track shutting down til March.
No they were not installed, I took them off the old rotors and installed on the new ones. They have a kit that has the new pins, I didn't order it, didn't know I needed to until I was in the middle of the change out.
didn't torque them down just tightened them up to what felt good, didn't have any reference to any torque specs? sorry no info I was not able to find any info on torque, maybe something in the kit ?? They were not all that tight when I took them off. sorry that I am not that much help on the torque specs. maybe someone else knows what they should be torqued to?
This thread discusses what the GT3 (center lock) guys are following in terms of torque specs.
You guys with centerlocks need to get your centerlock nuts torqued!!!
Sorry about that. Did a quick search and found this write up.
Rotor Replacement - vividracing
Put the new Brembo rotor in place and fasten the philips head screws. Grab the caliper and then slide it over the rotor and place the 10mm allen bolts back in place. Use your Torque Wrench and tighten them down to 55lbs each.
On Center Lock 997.2 GT cars the rotor has 5 red drive pins screwed to the rotor...it is these short nub drive pins that you replace with rotor changes I'm asking about.
I need a workshop manual...lol
04-28-2022 12:38 AM
2lflat4
11-18-2019 05:05 PM
