engine ticking
engine ticking
after leaving the car in the garage for a few days, i started it up to an unfamiliar sound. the engine was ticking ! the sound clip is me holding my iPhone over the engine…from left side and eventually to the right side.
i can't figure out how to embed the sound clip, so attached is the zip of the file.
any thoughts ?
2007 C4S that just crossed 50,000 miles. It was about 7 deg celcius, so not particularly cold.
any thoughts ?
![Red face](https://www.6speedonline.com/forums/images/icons/icon11.gif)
any thoughts ?
any thoughts ?
![Embarrassment](https://www.6speedonline.com/forums/images/smilies/redface.gif)
I put the car through the ringer this morning and it seemed like the ticking subsided. It is a helluva lot quieter than my sound clip. Now I gotta deal with the chirping coming from the belt/pulleys. Now that is really annoying !
Thanks to all for your replies. I'm definitely going to keep an eye on it going forward.
I am basing this on owning Pcars from decades past, but my first thought when I hear that is valves. On a a mid 80's Pcar, you start getting that "ticking" you need to start thinking about when to get the top end redone. Not a huge hurry...but you need to start thinking when in the next two years should I do it. On a currrent model...not sure. I would probably get it checked out though as I don't think most people would call that "normal"...at least my car doesn't make that noise on start up.
any thoughts ?
any thoughts ?
My valve train noises went away when I switched to Motul 5w-40 then to Castrol 5w-40 with less noise. I won't go back to Mobil1.
My 2008 C2S does not make that ticking noise. I do not know which oil is currently in the car; it was changed by the dealer before I took delivery. However, I remember that ticking noise from a different (non-Porsche) car I had owned, and I *was* exclusively using Mobil 1 at the time-- so this is an interesting theory.
Also, regarding the chirping noise from the belt, one mechanic's trick I learned was to spray WD-40 on the inside of the belt (the side that contacts the drive pulley) with the engine running so you lubricate the entire length of the belt. This was very counter intuitive, and I thought it would cause the belt to slip even more. I was quite aghast when I saw the mechanic doing this to my car, but it actually worked, and the chirping stopped with no adverse side effects.
04-28-2022 12:38 AM
titannero
Audi
08-31-2015 01:33 PM
