WOW! ROTtec 997.1 DRL LED's
#61
Could anyone please post picture of the hack (if I may) that is needed in US markets for making the LED DRL function as a daytime running light?
Specifically pictures of installing TFLM03 module or equivalent (25 Euro), wiring to battery, need for (2 or 3 ?) T / tap connectors?
#64
Not yet fixed...
I pulled the whole assembly and re-seated everything and still getting it. By the way, getting the assembly out again was a nightmare in comparison to getting the original out, so woe to those that are stuck like me redoing this.
I ran out of light, so I'll give it one more try tomorrow...
#65
What year is your car?
I think if you have a 2005-2006 you maybe having issues and may need a module. I know when Dectane Rear LED Tail Lamps came out, the guys with the 2005-06 cars needed to install the module that cam with the lights, guys with the 2907-08 cars did not need them, maybe you have the same issue?
#67
Issues here also. Seems many of us are having the same issue. All my lights are working as they should and i even put some insulation tape around the connection for the middle light strip to ensure connection was maintained. However, no success.
I have 2 sets of errors after fitting (fitted drivers side first then passenger side)
1) When lights are off, i get a Left Indicator Error that appears and then disappears once I have used the indicator. Odd !!
2) More worryingly, is when i turn the lights on to side light or full lights, i get a Left Side Light Error and then Right Side Light Error, so meaning the middle light bar. The fog lights (LED strip) causes no additional errors and the Left Indicator error does not come on when the lights are on.
Any thoughts ? did you see anything similar ?
Ray @ ROTtec aware and trying to help.
My car is registered March 2007, Build Jan 2007 i think. Also with my Dectane Rear LED light i used the resistor and it works.
Ray - WE NEED HELP !!
#68
I'm thinking you guys that are getting these type of error messages, especially on earlier model cars, you may need to add a resistor unit to get the error messages to stop. You can get the resistor units from Superbright LED's for very little money.
#69
My recollection of some of the earlier threads is that they were tested on various model years and types. Hmm...
#73
Before actual production, we have try the same prototype DRL to 05, 06, 07, 08 997 and they're all work without warning. I don't think module or resistor will fix. I'm asking the build date for all car with this issue and working closely with factory for solution. So anyone who has similar issue, please email me at info@rotteccarbon.com
#74
No, the module just gives you automatic DRL functionality. It will have no impact, good or bad, on how the PCM monitoring system detects the new lights.
