WOW! ROTtec 997.1 DRL LED's
Ray installed my DRL on my car this past Saturday. The quality and workmanship of the product appears to be first quality. The light assembly housing latching mechanism is flawless. I installed the Dectane DRL module and the whole system works perfectly. The front and rear LED lights make a dramatic improvment to modernize my 997.
Ray runs a first class operation and I am very impressed with his professionalism.
If you use T taps you arent damagimg the wiring so if you ever want to remove the hook it can be done in 5 minutes.
Hey Ray, don't I at least get a free hat or something for figuring out the DRL module install for you? You could just throw it in with my DRL shipment that hopefully is coming soon.................
I should, will do when we have hat or t-shirt painted !
Thanks TT2911!
You only have 2 choices: 1-Splice the module into the OEM wiring per the instructions I provided, this way you get true DRL function but your foglights still work as OEM foglights when you turn that switch on. 2-Wire the DRL module direct to the lower row of LED's/foglight position. This will give you DRL function but you will lose normal foglight operation.
Pardon my stupid questions:
1) Do I need 1 or 2 Dectane DRL modules ( i.e. 1 for each left and right)?
2) What is a T-tap? Appreciate if you can post/PM a picture
Thanks!
You only need 1 module. Just go to Home Depot and tell the guy you want a crimp connector that will allow you to tap onto a 14ga wire. They will probably be blue and cost you about $4 for a package of 8.
