Battery replacement
Battery replacement
Going on a long road trip, thinking about replacing my battery, any suggestions other than OEM, thinking about an optima battery, but I would need to make a custom bracket. Thanks in advance.
Wal-Mart MAXX 94R - direct size replacement, great warranty and reasonable price.
The manufacturer of the Walmart batteries is JCI. They are the leading lead acid battery manufacturer in the world. Do not be afraid to buy a battery for your porsche from walmart. I did and the 94R works great.
Put an Optima in my 996 worked great. After 5 years replaced it with another before it failed. Tested the old one it still had 50 percent left. I made the hold down out of some plastic I think. Traded it in with a nearly new Optima.
http://yellowdogmotorsports.com/store.php#special
I have one in my 997 - works great.
Very easy install. You'll have to swap out the postive cable with the longer one provided and IIRC you'll need to get the Red Top 34R (it has the terminals reversed so all the cables will reach).
Ran out of time to get the adaptor plate for the optima, back to the Maxx 94R,
went to WalMart to get it but the battery does not have a vent tube, is it important to vent the 94R battery? Should I get the battery and let the vent
dangle unattached to the battery? There are no venting options for the 94R.
Anyone can help me with this, first leg of my trip starts on Wed at 4am, driving about 950 miles that day.
Did they change the MAXX 94R battery?
Walmart shows this picture
http://www.walmart.com/ip/Everstart-...ttery/16782713
But that does not look like the Maxx 94R battery shown here (scroll to bottom of the page)
http://forums.rennlist.com/rennforum...ncement-3.html
The rennlist listed maxx 94R battery seems to have a vent tube attachment (and looks completely different), but the one shown on the walmart website doesnt. Maybe you just cant see it from the walmart picture?
evolveC4, is this the issue you are having? Which battery do you have?
My 94 R vented on the side. It came with a vent plug for one side, and I attached my existing vent tube and adapter to the other side (Passenger side if I recall correctly). I'd just stop by the local wally world and take a look at the batteries on the shelf to be sure. If you do buy, ask an employee to get a fresh one out of the back. Sometimes the visible batteries on the shelf can be pretty old and ratty.
