oil drain after sitting...horrible noise@startup, expected?
Hey fellas - had a question , probably obvious to many of you.
But, if I let the car sit 7-8 days (rarely do, just when vacation, otherwise is a DD), when I start it up, it sounds horrible like the engine is going to hell! Loud lifter noise and plume of smoke via exhaust. After 60-90 seconds, the sound normalizes to the usual.
Does this happen due to oil near completely draining out of the engine?
Any way to prevent it? Is it normal for oil to near completely drain and have this issue on start up after sitting?
I asked the service advisor who gave the explanation of oil completely draining.
I am the guy whose 997.1 had a scored cyl (#6) back in Nov 2010 and eventually got a rebuild.
Thanks for helping out with your advice, much appreciated
Sorry, not normal. Something's fubar'd. Take it back to the rebuilder although the usual warranty is usually one year. Get it checked out by some reputable shop before it's completely effd up. This should not be happening. Good luck, best wishes.
Sometimes when the car sits for awhile oil can pool in the cylinders and cause a little smoke at start up. It seems to happen to me if I wash the car move it back in the garage and let it sit all weekend.
The loud noise was probably a stuck lifter. They are hydraulic so once the oil pressure gets up it unsticks. I wouldn't call it 'normal' but it's happened to me before.
Here's a link to a similar problems:
https://www.6speedonline.com/forums/...y-lifters.html
http://forums.rennlist.com/rennforum...-s-engine.html
My car sat thru a few cold nights for Florida, 30's, and at start-up I had something similar, only lasted 30-45 seconds, no smoke though. Took to dealer and advised sometimes happens after sitting.
I live in the mid-atlantic and we get some cold nights. I've never had a noisy startup. Every once in a while I'll get a puff of white smoke at startup, but that too is pretty rare. I have an '06 3.6L
never an issue here. aside from a little puff of smoke after sitting over night.
if you are under warranty, i would have the engine checked out. compression leak down test at least. porsche covers 2 yrs on rebuilt engines. if you went through an independent, you are probably SOL.
Try to take a video with sound and show it to mechanic.
There are 2 major sounds at startup - chain rattle and valve lifters. My lifters do not knock, chain rattles a bit until tensioner gets oil. Nothing of it sounds 'like hell', may be 15% louder than normal engine sound.
When lifters knock it sound like somebody hits an empty pot with a metal spoon and when you add up rpms sound fastens then dissapears.
Chain tensioner is normally the rattle heard after it has bled down from standing. Imo lifters should not be that noisy. Are you getting full oil pressure immediately on startup? I've never seen smoke but it is reported. I assume this is a remanufactured/replacement motor. There could be a problem in the top end. I would call Porsche Customer Satisfaction and make a little noise of my own to a regional rep.
ECS Tuning - VW
09-02-2015 01:47 PM
ECS Tuning - VW
09-02-2015 01:19 PM
ECS Tuning - VW
09-02-2015 12:58 PM
