no start after stalling at a light
this is a new one, anybody else? turn the key and nothing, after about 10 seconds, turn off and remove key, thought that didn't seem to be the cure, maybe it was a time thing...but dangerous, car wouldn't start right away, i don't think this is normal, i recreated the situation again and the same thing...takes about 10-15 sec and then starts normal...
Hopefully it s user error... I m still learning my car and that has happened to me already. Forgot to re cycle the key all the way off.
The first few times I stalled my car I was so embarrassed that I panicked and forgot about the reset. Now whenever I let someone drive my car I warn them about how to restart if they happen to stall.
Plus you probably reached for the key on the right side - it's happened to us all.
it is a pita - you got to get key out, release clutch, then put key back in, press clutch and only after that it will crank. i always wondered if there is anything in the ECU setup that can be altered to turn off this BS. it was a major PITA at AX if you would stall car after a spin - damn thing just does not want to start back.
