Hex nut came off of motor mount...
Was driving oddly enough to the grocery store along a patch of glassy pavement when suddenly the back end shuddered as if I had struck a pothole (no pothole within site). Car seemed to be driving fine, no CELs, so I drove the remaining mile to the store. After shopping I returned to the car and noticed that the right rear bank of exhaust tips was sitting several inches lower. Upon further inspection it appeared the whole engine had canted approximately 20 degrees.
I Called the dealership and had the car towed back where upon further inspection they informed me it was a nut that had loosed and came off (apparently this is the first time they have seen this happen). The nut was replaced and they assured me that no damage was caused. The car seems to deliver identical power as previously but also now appears to idle more roughly. The tach is still set solidly slightly under 1k revs at idle but it seem there is significantly more vibration into the passenger compartment. Does anyone have any thoughts as to what may be amiss or is this possibly all in my head? Car is bone stock 2005 C2S (launch car) with about 17k on the odometer and has been maintained appropriately.
Thanks in advance.
Thanks in advance.
I have a 997.1 turbo and often times see the tach idling in a slightly twitchy manner. People say it is normal. I wonder if better motor mounts would increase shifting feel and drive ability.
Allegedly the other mount appears to be fine. Kind of a weird thing to have happen. I was wondering if this could have caused the fly wheel to become canted a tad although the mechanism of the motor shifting was pretty gently likely in the grand scheme of things. Oddly enough now the front boot doesn't pop up all the way any longer. Grrrr.
Never, that's what makes the event so bizarre. I actually was at the dealership earlier driving one of the 991s and after coming home from the test drive, kerplunk. I really trust the guys at my local dealership, and respect the mechanic whom has actually talked me out of service in the past. Simply one of those freak things that happen to cars. They got the new nut, made sure everything was torqued down appropriately and road tested it. The car seems to make great power and drive essentially the same other than a bit more vibration in the cabin at idle that I had not noticed before.
In all seriousness, maybe the actual engine "feel" was disconnected due to the loose bolt and tightening the bolt took it back to "normal".
This would be my guess as well. The new feel may just be because things are right again. The frunk lid sounds unrelated.
COBB Tuning
01-05-2016 07:06 AM
alpha motoring
10-02-2015 12:04 PM
