Oil pump gear broken
My car carrera2 997.2 2009 manual transmission, The mileage is 32500 miles or 52 303.68 kilometer.
Did anybody know if the oil pump gear broken is it effecting on other part of the engine.
Thanks Advance
Thanks Advance
How do you know it's broken?
Did you drive car w no oil pressure? Did pieces of broken pump circulate in engine w the oil? Do you just need to replace the pump? You need to ask this of a technician who has seen the car. Hope for the best for you.
Thanks for your response jhbrennan and Gpjli
My problem is always i changing the gears until the
revolution reaching the red line
The picture of the crack
http://imageshack.us/f/843/20120325145252.jpg/
Thanks to you guys
Thanks to you guys
This must be the oil pump housing. There is no oil leaking, so this portion may not have direct contact with oil that circulates in the engine. However, this cracked housing may have affected how much and how effectively oil reaches the moving engine parts, resulting in damaging wear. In addition to taking this to a knowledgable mechanic, have the oil drained and tested for metallic content.
Also my other mistake is always keeping the oil level more than 400 milliliter below the full mark plus the always the rev on the red line + the modifying, but in the accident time the level was correct.
Also i never taking the vehicle for service i do all service with my self.
There will be some oil in your oil filter housing. Carefully remove that, without spilling, and have that oil tested. If this has already been removed and emptied out, I would still drain some fresh oil *after* the repair, and have that tested to see if there was some long term damage that is resulting more metal particles.
Thanks for your recommendation PSPorsche, also i will try to put a magnatic in some areas like a drain plug.
Before the problem, am sorry for that laugh in the video, always we are forget that camera is recording.
The engine failure
Thank you guys
The engine failure
Thank you guys
Note: DME or ECU is stock, not touched.
I opened the pan at home and this is what i saw, i have no idea the problem from the liner or from the connecting rod, whatever i need new engine now.
Is it right the total cost for new engine with labor charging is approx 12,000 $us in porsche dealer.
http://imageshack.us/f/594/20120330072128.jpg/
I can't see this video On the first few days from this problem. really it's hard, but i still love PORSCHE.
Thank you mattyf
Thank you mattyf
Good to remaind me to put the report
Sorry if not clear this is the best i've got
http://imageshack.us/f/14/problemdj.png/
Thank you
