Gundo hack on the way
Rating: Thread Rating: 3 votes, 5.00 average.
Old 03-31-2012, 12:27 AM
slick911's Avatar
slick911 has a spectacular aura aboutslick911 has a spectacular aura about
Use 10mm deep socket and the 10" long extension to remove the upper screw along the stick that is attached to the lower bumper corner. Use the T-30 torx for the other end of the stick attached to the bumper.
Old 03-31-2012, 12:41 AM
slick911's Avatar
Use 1/2" short socket, flex joint and 20" long extension to remove final two nuts from the muffler bracket inside the wheel well. Muffler can now be removed. It's a little tight so some wiggling is needed but sure is hell of alot better than removing the bumpers. Repeat for other side and reverse for install. That's it folks. It was easier than I thought. It took me about an hour to drop the right muffler and 20 min to drop the other. First side took longer because I was "lolly gagging". For those of you that's gonna ask what to do with the jack, STOP, don't try this at home and take it to a qualified technician.
Old 03-31-2012, 12:45 AM
slick911's Avatar
Before and after of the cans. Now that's what a weld bead should look like. Good luck. PM me with any questions. Be happy to help.
Old 03-31-2012, 02:29 AM
BayAreaTim's Avatar
BayAreaTim is infamous around these parts
Thanks for the write-up. Makes me want to do it even more now!
Old 03-31-2012, 11:24 AM
AP 997S's Avatar
AP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud of
Your weld job looks like one of the best I've seen w/ respect to the 'Gundo Hack'. Most look like they've been done by 1st year auto shop students.
Very Nice . . . .
Old 03-31-2012, 12:43 PM
slick911's Avatar
I am gonna sound like a broken record but it sounds AMAZING! Keep in mind I have the center Xpipe too so I would not know how it would sound with the oem center muffler. It only cost me about $100 out of pocket and some of that went to Lowes to buys tools I didn't have.
Old 03-31-2012, 12:51 PM
slick911's Avatar
Very Nice . . . .
I went to a motorcycle builder instead of a muffler shop. This guy does a lot of work for me for my mfg business so I was confident in his quality. You are right. Some of the pics I have seen shows low quality welds. Probably wasn't preheated b4 the actual weld.
Old 03-31-2012, 02:11 PM
DoninDEN's Avatar
DoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond reputeDoninDEN has a reputation beyond repute
It's DONE!! And music to my ears!! Shoulda effen dun dis waaaay sooner. Wish I know how to post videos but here's my current set up. Gundo Hack on both left and right mufflers and Fabspeed Xpipe for the center bypass. (don't know why I said "both left and right" cuz why would anyone only do one side? ) Let me share some of my findings. I had a hard time finding DYI for the 997.2 (plenty of useful info for the 997.1 as the principal are similiar), it's probably out there, I just didn't see it so I decided to create a DYI for us 997.2 folks that want to tackle it themselves.
Tools you'll need:
20 inch long 3/8 drive extension
10 inch long 3/8 drive extension
3 inch long 3/8 drive extension
10mm deep socket (3/8 drive)
1/2 inch deep socket (3/8 drive)
1/2 inch short socket (3/8 drive)
3/8 drive ratchet
3/8 inch flex coupler
T–30 torx screwdriver
3/8 inch socket (12 points, 1/4 drive)
3 inch long 1/4 drive extension
1/4 drive ratchet
Screw jack
Attachment 173494
Awesome!! Gundo is great!
Old 03-31-2012, 02:13 PM
DoninDEN's Avatar
Very Nice . . . .
Don't sweat pretty, they're mufflers. What is noticed is the great sound!
Old 03-31-2012, 03:14 PM
AP 997S's Avatar
Workmanship & quality don't have to seen to be appreciated. Case in point would be some sort of surgery. You might not see it but if it's done right w/ great workmanship and quality you might never have to deal it again.
One of the reasons we buy Porsche cars is because of the inherent workmanship and quality that goes into the build process. Why bugger it up w/ a crappy welding job when w/ a bit of effort it can be done properly.
Have a nice day . . . . .
Old 04-01-2012, 05:09 PM
slick911's Avatar
Absolutely agree! A muffler is a muffler. Insignificant item. Thats why we send it to get butchered, right? At the end of the day we all can agree that the Gundo hack sounds amazing. For me though, being an OCD, if it wasn't done right I know I would be thinking about it all the time so with just so little effort to have it done right, it was an easy decision to make. To each his own.
Old 04-01-2012, 05:11 PM
slick911's Avatar
Originally Posted by BLKonBLK911C4S
My gundo will be done Next Wednesday....Can't wait.
BLKonBLK,
Post your thoughts after yours is done.
Old 04-04-2012, 03:16 PM
camds's Avatar
camds is infamous around these parts
Slick 911, would you be open to referring me to your welding guy? I live in LA as well and would love a good referral...
Old 04-04-2012, 03:35 PM
slick911's Avatar
Just PM'd you.
Old 04-04-2012, 05:30 PM
BLKonBLK911C4S's Avatar
BLKonBLK911C4S is infamous around these parts
BLKonBLK,
I posted in a new Thread (https://www.6speedonline.com/forums/...-complete.html).....The sound is awesome. I only went with a 1 3/4 and I am very happy. Since my car is a daily driver i did not want anything too ear shattering
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
Quick Reply: Gundo hack on the way
