Engine Mounts - How much did you get out of yours?
48k miles, seems like there is a some higher than normal vibration developing at idle - otherwise normal any other way. I think it's the engine mounts.
Just wondering how many miles you guys got out of yours before you had to change them...
What symptoms were being noticed that suggested to the dealer they were defective ?
vibration at idle was enough to rattle your teeth sitting in the seat. The car is noticeably smoother at idle vibration wise after new mounts.
I have solid mounts, and hard back seats with very little cushioning and there is very minimal vibration with mine. Maybe my teeth are still tight in the gums
Solid or OEM
So it would seem that my engine mounts need to be replaced to get rid of that teeth-rattling vibration at idle. Anyone out there has experience with both OEM and aftermarket solid engine mounts to say which one I should go with?
What do you use your car for? Track or Street?
Track, go solid for sure.
Street, go OEM for sure.
The solids create more noise then the OEM mounts, and it is not for all. My car is more raw then most. The solids will never get worse then they are the day they are installed.
One other option is the Revo Semi Solid Engine Mounts if you want an in between solution, or if the OEM are expensive.
Or one can consider the OEM RS semisolid engine mounts. Similar pricing as WEVO, but not as nice looking...hehehe
04-28-2022 12:38 AM
nlakind
11-06-2015 10:15 AM
pwdrhound
08-23-2015 07:36 PM
ECS Tuning - VW
08-19-2015 08:58 AM
