Tire Pressure Monitor
New "to me" 911. I cannot find the tire pressure monitoring screen anywhere. I am 99% sure I seen where you set it when the salesman was showing me the car. I have gone through the On Board Computer dispaly (center tach) and I cannot find it. Maybe I don't have TPM? How do I know?
Nice.
I like both of the first two avatars in this thread.
when you push forward (toward the front of the car) on the lower left stalk you will have accessed the list of features you have available..
up and down on the lower left stalk will cycle you thru them... I think mine says TPS...
When you find the group that you want to go into, press forward again on the stalk... and then up/down to cycle thru those...
pull back to exit that menu..
07 cars should all have TPMS... but if you are lucky you won't have it, because it is a total POS... wrong readings, wrong wheel sensor positions etc... nothing but dash lights for me now, so I wish I didn't even have TPMS..
Our '09 Boxster had TPMS, and it fluctuated quite a bit, so I was always a bit distracted. Our 997 has TPMS, and it's been consistently accurate. The tires are nitrogen filled, so maybe that makes a difference somehow. I was also told by a Porsche parts guy that you have to use a valve cap specifically for a TPMS equipped car for the system to work. I don't know whether that's true either.
04-28-2022 12:38 AM
RallyBird
10-07-2015 01:20 PM
horsepowerfarm
09-10-2015 06:09 PM
COBB Tuning
09-09-2015 09:13 PM
